Starves for gas while driving
My 92 F-350 staves for fuel whenever I drive it for more than 30 mins. I believe its a fuel pump issue. Ive recently chged the plugs, filter, and other minor things that might also cause this problem. If the fuel pump is the actual problem, where is it even located. Some help would be appreciated.
X2 of what Paul said
I'll add that if it is starving for fuel, it could be that the fuel pump is clogged or the small, dime-sized diaphragm inside the pump may have lost it's seal. Both of these happened to me, on different occasions. Either way, replace it if it's bad. And for my truck, yours might be similar, it's easier for me to raise the bed than to lower the tank.
Ed Trethewey
04-11-2004 11:00 PM
1yamman350
16
12-29-2003 05:17 PM
