Convert dually front end to single?
I found a dually in the junk yard that is an old tanker 4x4 truck. It has the D60 front end that looks like it has been converted over to hydralic steering of some sort. Its an 87 superduty with a 7.3L and 4.10 gears. I have an 86 that id like to use it in. Is there a way to convert this to work on the 86 F250 SRW?
If so you can just remove the Dually hub/adapter and put on one from a single wheel dana 50 TTB or Single wheel dana 60. It is that simple
Yes, f- superduty. That will be nice! Can pick up a ball joint D60 with 4.10 gears for 270. Now just need to figure out what to do with the rear that has 3.55s in it. Just a mud truck, will see no pavement. I'd like to do a locker in the rear and an ls or some sort for the front with 5.13 gears. That way I can sling some mud with these 38s and stock 351w...
Received 3,090 Likes
on
TheMechanicalAnimal
07-29-2010 08:50 AM
asigalet
11-02-2005 11:51 PM
Bonestock
03-22-2005 03:14 AM
dpoelstra
07-07-2002 03:32 PM
