Running the exhaust under the gas tank
Old 06-04-2012, 09:37 AM
Midnightride42's Avatar
Midnightride42
Midnightride42 is offline
I've been wanting to run a true dual exhaust and have a pipe exit in front of the tires on both driver and passenger side. As everyone knows the gas tank is in the way.
I have the factory skid plate under the gas tank.
If I run a pipe under under it, wouldn't the air running under the truck keep the pipe cool? Also, the skid plate should keep any of the heat the pipe creates away from the gas tank correct?
I know you'll be able to see the pipe if you look under the truck, but as long it's not going to affect the gas/tank I'm ok with that. Truck sits high enouph for it not to hit anything going down the road. I dont off road either.
Just wanted to get some opinions on rather or not the heat from it will affect the gas tank. Again the Skip plate is there.
Thoughts, suggestions?
Thanks!!
ps: this is on a 99 5.4 4x4 extended cab.
Old 06-04-2012, 06:29 PM
V10man's Avatar
V10man
V10man is offline
I had dual exhaust like you want on an older Ford. I ended up hating it. Every time I went to a drive thru I had to shut the truck off to comunicate and that was with turbo mufflers. I think you'd be better off cutting out the Y and running the duals down the passenger side. Here is a pic of what I did to my 07 5.4L:
Old 06-08-2012, 10:38 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
I agree w/ V10man, had exhaust exit in front of the rear tires on my 65 for way too many years. Rcently had shop route them out the rear and it's like the difference between night and day. If you have A/C and keep the windows rolled up then perhaps; otherwise, suggest routing anywhere other than near the cab and save yourself a 'headache'.
Old 06-08-2012, 10:59 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Besides which, your fuel pump will not last forever. In most cases you either have to drop the tank or remove the bed to get to the fuel pump. If you have to drop the tank, do you really want anything in the way.
I agree with the others hear, true duals are overrated at best, most who have gotten them are disappointed with the results, especially considering how good false duals sound. The true duals have no performance benefits, so why would you want to?
Midnightride42
1997 - 2003 F150
06-04-2012 10:23 AM
felixr
2004 - 2008 F150
03-06-2008 11:30 PM
Desertwolf
08-11-2006 10:17 AM
jrreed1634
Exhaust Systems
01-03-2005 08:03 AM
XXL-RG
07-02-2004 04:31 AM
Quick Reply: Running the exhaust under the gas tank
