Oil change 2001 7.3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Oil change 2001 7.3
Old 06-04-2012, 12:23 AM
Bvill01 Bvill01 is offline
Bvill01 is starting off with a positive reputation.
Oil change 2001 7.3
When you change the oil is there a plug by the fuel filter that you need remove and pull out the oil from the intake can someone tell me?
Old 06-04-2012, 01:10 AM
DND58's Avatar
DND58 DND58 is offline
DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.DND58 has a good reputation on FTE.
Not really necessary. Drain the pan, replace the filter(fill with oil first), and top off crankcase oil.
HPOP is near fuel filter, and some think changing helps or is necessary.
Old 06-04-2012, 01:16 AM
Thank you !!!!
hpop oil change jccapri 1999 - 2003 7.3L Power Stroke Diesel 20 12-21-2012 10:35 PM
How to change the oil? Stinkweed14 6.4L Power Stroke Diesel 18 09-15-2011 08:33 AM
Changing oil Andy's250 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-01-2009 10:12 AM
How long between Oil Changes --Synthetic gordonh8r 1999 - 2003 7.3L Power Stroke Diesel 23 08-19-2008 08:57 PM
oil change warranty grady208 2004 - 2008 F150 7 03-15-2004 12:41 AM
Tags
2001, 73, 73l, capacity, capcity, change, changed, diesel, excursionoil, f250, ford, international, oil, spec, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
