1978 - 1996 Big Bronco
Do I have a transfer case mount?
Old 05-06-2003, 08:20 AM
mnm99's Avatar
mnm99
mnm99 is offline
I am trying to fing this banging sound near the center of the truck when going over bumps...The bigger the bump the harder it sounds. The entire front end is rebuilt and all my u-joints. I'm now looking at my tranny mount. I can move it up and down with a pry bar pretty easy and noticed the metal stopper in the bushing may be hitting the top of the mount. Is there also a mount for the trasnfer case also? I notince when it is put from park to drive the transfer case bounces around a bit. Is this normal?
Thanks.
Old 05-06-2003, 08:32 AM
steve83's Avatar
steve83
steve83 is offline
The t-case is only mounted to the back of the transmission extension, just behind the trans mount. If the t-case is moving independently of the trans, you've got a BIG problem - tighten the t-case mounting bolts. Check the Haynes manual or here.
Old 05-06-2003, 11:16 AM
mnm99's Avatar
mnm99
mnm99 is offline
I'm pretty sure the TC is tight. Maybe the tranny mount is bad . I guess I'll replace that next. How hard is that to do? Could I get to all the bolts and just raise the tranny with a jack?
william16339
12-21-2015 12:43 PM
redmun
12-13-2013 12:54 PM
Navyguns
Aerostar
06-28-2012 08:11 AM
yellkayak
1999 to 2016 Super Duty
06-26-2012 09:44 AM
digger19
11-09-2010 10:56 AM
Quick Reply: Do I have a transfer case mount?
