When parts break at a GOOD time
Leaving my driveway today ( I live in Philly,so its street 20 ft away),i went to tap the brakes to slow down and she kept going. Pedal went to floor,slammed emergency brake and got her stopped.
Thank god it didnt happen 5 minutes later as i was on my way to pick the wife up at work driving on the highway.
After a minute of looking,i found the steel line over differential pouring out fluid.Right where the clip that holds the line to a bracket at top of diff was rusted bad which showed the blowout hole underneath. I always knew that brake lines held high pressure,but man,the entire underside is covered in brake fluid.
My question is has anyone ever used this new stuff
Brakelines/Brake Line (PAX-572) | 1995 Ford E350 1 ton Van 6 Cylinders Y 4.9L EFI | AutoZone.com
Or should i buy the 25 ft coil and flare the ends myself as well as the fittings
Almost the same thing happened on a friend's '99 E250----it sits far more often than he ever drives it. Without warning as it almost always the case with rusted brake lines he discovered failing brakes, luckily at a good place and time. Glad both of you didn't suffer anything more serious than soiled shorts!
Like Josh says the stock lengths tend to be fine but most likely you'll need to cut and re-flare a few ends, quite possibly replacing one or more junction blocks too if re-doing the whole system. The PVF coating is interesting--can't hurt using those coated lines if you're already replacing some of all of your existing lines. I'm guessing you have a good double flaring tool or at least access to one?
R-WEST
12-31-2016 11:55 AM
