Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- How to Replace Your Blend Door
Step by step instructions for do-it-yourself repairs
I think my blend door actuator is going out
Whenever my A/C is turned on, it blows nice cold air. As long as the blower is on "1", "2", and sometimes ", it blows cold air. If I turn it to "4" I can hear a small "thud" behind the dash. It sounds like the blend door is shutting. All my functions work like they should. I think the actuator is goin out and isn't pushing the door all the way closed, and when I turn it to "4" it pushes it te other way. What do you all think? Please help!
Well I have the temp control **** all the way in the cold position. Would it be possible tht tht actuator doesn't have the "umph" it needs to fully close in that position? I know it stays in one position, I'm just wondering if it were going out would it not quite reach that full position?
Your blend door may be broken. Common problem. The whole dash has to come out to fix it though and you may as well replace the heater core whole your in there. See if the air temp changes when you accelerate from a dead stop and if the it again changes when you brake to a complete stop. If so, it's a broken blend door. Big job to replace it.
