I think my blend door actuator is going out - Ford Truck Enthusiasts Forums
Old 11-17-2014, 06:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
Old 06-03-2012, 06:25 PM
Harkijr Harkijr is offline
Harkijr is starting off with a positive reputation.
Whenever my A/C is turned on, it blows nice cold air. As long as the blower is on "1", "2", and sometimes ", it blows cold air. If I turn it to "4" I can hear a small "thud" behind the dash. It sounds like the blend door is shutting. All my functions work like they should. I think the actuator is goin out and isn't pushing the door all the way closed, and when I turn it to "4" it pushes it te other way. What do you all think? Please help!
Old 06-03-2012, 10:35 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the blend door is a varialbe positoion, electric motor control door. It does not "flop" back and forth. It stays in one position to control the air temp by mixing hot and cold air. If you have good temp control, then its fine. If you can not control the temp, then you have a problem.
Old 06-03-2012, 11:15 PM
Well I have the temp control **** all the way in the cold position. Would it be possible tht tht actuator doesn't have the "umph" it needs to fully close in that position? I know it stays in one position, I'm just wondering if it were going out would it not quite reach that full position?
Old 06-04-2012, 06:47 PM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
Your blend door may be broken. Common problem. The whole dash has to come out to fix it though and you may as well replace the heater core whole your in there. See if the air temp changes when you accelerate from a dead stop and if the it again changes when you brake to a complete stop. If so, it's a broken blend door. Big job to replace it.
Old 06-04-2012, 10:12 PM
Unless I go with HeaterTreater right? Haha! Alright I'll try that. I hope it's the actuator. Cause I don't feel like pulling the dash or cutting any holes in my heater box. Lol. How much of a chore is it to change a heater core?
Old 06-05-2012, 06:36 AM
Once the HVAC box is out from behind the dash, a panel on the box can be removed to observe both the heater core and the blend door. I've seen that "heater treater" video, repairs (if you can call it that) don't get much cruder than that.
Blend door actuator danomac Ranger & B-Series 6 10-02-2014 09:44 PM
Blend Door Actuator GloveGuy Cooling, Heating, Ventilation & A/C 2 08-11-2013 09:43 AM
Blend Door Actuator Problem Is there a fuse or relay 2006 f350 Jawbreaker 1999 to 2016 Super Duty 4 09-11-2012 12:07 PM
1997 f150 heater problems. bballard1559948 1997 - 2003 F150 6 12-14-2011 07:00 PM
04 Expd A/C blows hot in front, rear ice cold gpmarko5 Expedition & Navigator 3 07-28-2010 03:50 AM
Tags
03, 1997, accuator, actuator, air, blend, door, exchange, f150, flex, ford, fuse, number, replace, temperature, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
