Extra power tips for pulling with a 98 .5.4
You have no access to change timing because it's all in the computer program and is a 'computed' value applied to the circuits that fires each coil, as the conditons change while driving..
There is no external way as there is no distributer to move it's setting.
To get a little improvment requires a lot of money to accomplish by buying a program and hardware to install it in your PCM.
Good luck.
Good luck.
Agree with Bluegrass! Figured this out after spending money on things that in the long run added to the longevity of the truck but did little to increase pulling power.
So, for my birthday, I did a gear change! As we already had the programer it was a simple task to reprogram the computer for the new gear ratio.
Now I'm anxiously awaiting to see how we do pulling over the mountains!
Hope that helps...
Hope that helps...
rangedog
Modular V8 (4.6L, 5.4L)
03-28-2004 11:26 PM
