Rear 12 volt convenience outlet problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-03-2012, 03:41 PM
jimbob911's Avatar
jimbob911 jimbob911 is offline
jimbob911 is starting off with a positive reputation.
2010 F250 extended cab. The 12 volt convenience (cigarette lighter) outlet on the rear of the center counsel, will pull out of the counsel when trying to detatch a power cord. There doesn't appear to be anything holding it in other than the very thin plastic wall of the counsel it is mounted in.
I use the outlet a lot in my job. I power a vhf monitor radio, Garmin, spectrum analyzer, cell phone charger, as well as my laptop in a pinch. Not all at once, of course.
Am I missing a part? Does anyone have a fix for this? Unless I use both hands and a whole lot of careful wiggling, I always pull the electrical guts clear out of the counsel.
Awfully cheap way to mount the rear 12 volt convenience outlet imho.
Jim
Old 06-04-2012, 11:08 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
This issue should be covered under your factory warranty.
Old 06-05-2012, 05:04 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
I replaced my shorted front convenience outlet with a 3M brand one from Walmart - worked great after some minor trimming, and 1/5 the cost of the Ford part. It's a screw-together design that won't pop out like yours is, but you'll have to do some custom wiring if you go this way.
Old 06-05-2012, 06:50 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
As an interim step how about getting a cheap little cigarette lighter extender / adapter ?
that way you are not where out your permanent 12v receptacle ?
Amazon.com: 12v extension
I actually use something like that all the time to protect the factory one, and these cheapies are easily replaced
Overhead Counsel removal? Curt's05 2015+ F150 3 08-23-2016 07:43 PM
Center Counsels Ziegelsteinfaust 1961 - 1966 F-100 & Larger F-Series Trucks 8 06-13-2013 12:02 PM
Resetting MPG on my Overhead Counsel eechoo 6.0L Power Stroke Diesel 1 05-23-2008 08:43 AM
Another Explorer Bucket Seat Swap MemphisSenior Ranger & B-Series 6 06-02-2007 09:53 PM
Center counsel 12v outlet blown BP57 Expedition & Navigator 2 02-04-2007 02:01 PM
Tags
12, 12volt, 2007, 2011, f150, f250, f350, ford, issue, outlet, outlets, plug, power, switched, volt, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
