86 F150 Starter Solenoid Wiring - Ford Truck Enthusiasts Forums
Old 06-03-2012, 01:43 PM
westroud westroud is offline
westroud is starting off with a positive reputation.
I have four wires to connect to a new solenoid and cannot get the truck to start. I tried the battery cable on the bottom post (when mounted) ant the other three on the top post. I get no power to the cab or stater switch. Then I tried only the stater cable on the top post and the otheer three on the bottom post. The truck started but the starter will not shut off when the key is in the run position. What am I doing wrong?
Old 06-03-2012, 01:59 PM
82f100460's Avatar
82f100460 82f100460 is offline
82f100460 is gaining momentum as a positive member of FTE.82f100460 is gaining momentum as a positive member of FTE.
You should have more then just the 2 posts correct? At least on of those should be coming from your ignition to pull the starter solenoid in, when returned to run from start, the solenoid then drops out.
Depending on what engine you have, which you did not state, you may have another wire coming to the solenoid for the electric fuel pump while in start.
The side your battery connects to, should also have the wires going to your power distribution system/alternator connected to it. The other large post should go to your starter, and starter only.
If the solenoid is closed even in "Run", that could be due to you having it connected wrong or a bad solenoid. I know you stated it is new, but new ones fail quit often if it's one you purchased at a local parts store.
Old 06-03-2012, 03:53 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Post the wire colors with their stripes or marks, and I can tell you where they go on the solenoid, using the Ford wiring diagrams I have.
starter spinning but not engaging turbill Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 10-06-2015 06:31 PM
87 F150 Starter will not disengauge! droc9891 1987 - 1996 F150 & Larger F-Series Trucks 9 01-14-2014 05:51 PM
No electrical power at all? roosplash Electrical Systems/Wiring 23 03-14-2013 11:26 PM
Starter Solenoid Click But Engine Dosnt Crank 84F-250HD460 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 04-29-2010 11:25 AM
Starter Solenoid Hook-up 79boston150 Ford Inline Six, 200, 250, 4.9L / 300 1 07-15-2008 01:24 PM
Tags
150, 1972, 1986, 86, 87, diagram, f150, ford, relay, soleniod, solenoid, starter, sylnioid, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
