Exhaust temp. sensor problems - Ford Truck Enthusiasts Forums
Old 06-03-2012, 10:23 AM
mkelwk mkelwk is offline
mkelwk is starting off with a positive reputation.
I have a 11' 550, and have quite a few problems with it, was in shop twice this last week for exhaust temp. sensor failure. When that happens you get a nice little message to pull off road safely, and you better do it quick because it quits on you, and your done. Anyone else having these issues?
Old 06-03-2012, 10:39 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
There have been a few here who've run into faulty EGT sensors.
Was it the same one or different ones?
This is SOP with a EGT sensor failure.
Old 06-03-2012, 10:52 AM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
There's way too many sensors on the truck that can fail and leave you stranded.
Old 06-03-2012, 11:23 AM
It's just very irritating, this is my work truck, when it's down I'm down.
2011 F350 Temp sensor probe problem Glenn Bro 1999 to 2016 Super Duty 0 10-13-2016 05:49 PM
False Overheat Problem Solved JerrySLC 1997 - 2003 F150 6 07-26-2015 02:04 PM
89 Bronco 302 Temp Sensor Whitey Ford 1978 - 1996 Big Bronco 7 02-14-2015 07:52 PM
Help with a few SES codes... what they mean? and fixes? Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 21 01-07-2015 07:45 AM
Coolant Temp Gauge pmasley 1999 - 2003 7.3L Power Stroke Diesel 6 07-20-2012 09:49 PM
Tags
05, 2011, 67, diesel, engine, exhaust, f250, failure, ford, heat, light, problem, sensor, superduty, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
