Is this a good deal or should I keep looking
Looking to get a 2008-2009 f250 srw
I found this vehicle seems to be very clean
2008 King Ranch sunroof, factory navigation system, back-up camera and alarm, heated memory seats, 6-CD disc changer, painted tool box, spray in bed liner, new tires, 2 new Motorcraft batteries, dark tinted windows, electric rear window, electric folding/extending mirrors
90,000 miles
Is $28,500 a good price
How will it how it's value, if I keep for 2 years and it has 115,000 miles what do you think it would be worth
What questions should I ask
Anything I need to be concerned about
90,000 miles
Was there a maintenance schedule? If the truck had oil changes every 3500 to 5000. dif, tranny, coolant, fuel filters and other maintenance items were performed on time then it would be a good truck past 100,000. If none of these items were documented than the risk goes up. Does the dealer have the factory detail of maintenance performed? Did you get a Carfax report? I wouldn't buy a used diesel without a detailed maintenance schedule. Just my 02 cents.
What Rich said above times 2 plus, these trucks lose a lot of value when they pass 100,000 miles and are out of warranty. There are several things that can fail and cost a lot of money so owning one out of warranty is sort of a craps game. If you avoid a big dollar failure you win. If you blow up something that requires a cab off repair with lots of new parts you better have deep pockets. As to the price, with 90K on it I think I'd work on the seller a bit. Now if you could get some kind of extended warranty that would actually pay for engine repairs with it then you got a good deal. And, again i can't stress enough that the maintainance must have been done and done right. if they can't prove it then I'd walk. If it's on a lot and came from the auction then they have no idea and neither will you. Good luck
Not no enough information. fuel pump problem could mean someone not changing filters which is not good. Ford has an online system that end users can input their service even if they are a DIY service. If there is not significant mileage based service intervals in this sytem, I would walk away or get a great deal on it. As was said before, 100,000 miles without good service is a timebomb.
