Anyone using a BD Adjustable Track Bar?
BD 1032110 Ford Adjustable Trackbar Fits 2005-11 Ford Superdutys
Seems almost too good to be true for the price.
Anyone heard of BD or used any of their products??
An adjustable track bar would fix all my front end issues and until now the cheapest one I've seen has been $700-800. At $240 shipped that seems unreal.
Any input is appreciated!
Andrew
Andrew
I installed the Icon adjustable track bar with bearings on my 2011 F350. The salesman told me that if I purchased a panhard bar with bushings, the bushings would have to be replaced once a year. I have a year-and-a-half on mine and it is still tight. I can highly recommend the Icon Bar. Unless you have a torque wrench that goes to 406 ft/lbs, you don't want to have to replace the bushings once a year.
This is a link to the bar on the Icon Website.
Good Luck
64031 - 2005 - Current Super Duty F250 / F350 Adjustable Pan Rod Track Bar with Bearing - ICON Vehicle Dynamics
Good Luck
all this is presuming my theory of bushing quality is accurate
Depends if the caster has been addressed in the lift itself. If the radius arms are lowered you'll likely be fine. I haven't had mine realigned and it drives just as good as it did from the factory.
Camber and toe-in didn't change from lifting it and my radius arm drop brackets corrected the caster angle so I left it alone. After I install my adjustable track bar I'll adjust the drag link so the steering wheel is centered again and see how it drives. I might drop by the alignment shop to just make sure everything is within spec but I doubt it.
You'll likely be fine. See how it drives after it's all done.
Honestly if Rancho is any form of a decent company they would run it through an alignment shop just to make sure everything is right before giving it back to you. If for no other reason than liability.
Worst case, most alignment shops will check it for free and let you know what/if anything needs done. At least the shop I go to is that way. If might be difficult to find a shop that has a rack long enough for that thing to fit on though.....
Installed (2) BD adjustable track bars over the weekend and I can say they are great. Both went together nice and easy (the bushing takes some effort to install) and fits on the truck perfect. Very simple to adjust and has enough fine adjustment to get the axle perfectly center and keep it there.
In short, quality product that does exactly what it's supposed to for a great price!
I would buy one again and not think twice.
