99 F350 Blown fuse #8
Hi, I need help tracking down a short on fuse #8 radio / headlight switch. it is the black and pink hot in run wire. I have the fuse pulled, the radio and headlight switch connectors disconnected, the ignition switch and the plug to the GEM disconnected. I am sure the short is somewhere in the wiring harness unless there is something I am missing. Help for where to look would be appreciated. I can't imagine a wire has gone bad in the harness by itself, are there other connections / splices I am unaware of!
Thanks!
Thanks!
I would swap it out. Here's some places in California with a 99 truck. I went to Car-Part.com--Used Auto Parts Market and looked up "computer not engine" and you can see all the many choices their are and how many numbers there are for the different modules. I believe they are calling the GEM module the "multi-function module". But no junkyards came up, it's probably too much of a hassle for them to list all the different modules they have. So I looked up a front fender instead, and these are the ones that came up with that in California that were a 99. I am not sure if any of the other years will fit, and you will probably have to go to the yards, pull the module, and verify the numbers yourself. It's a little bit of work, but you can probably get it cheap that way. Just make sure it doesn't look like it has any water damage from a leaky windshield, which is a common problem in these models.
1999
Fender
Ford Truck F250 Super Duty RH,0S4 $TC328 $165 LKQ Specialized - Rancho Cordova USA-CA(Rancho-Cordova) Request_Quote 888-967-2787 Request_Insurance_Quote
1999
Fender
Ford Truck F250 Super Duty RH,Front, (w/o whl-lip mldg),WHITE EXT 000 A
0 T3744 $150
actual A-1 Auto Wreckers USA-CA(San-Jose) Request_Quote 408-225-5313 / 800-825-0064 Request_Insurance_Quote
1999
Fender
Ford Truck F350 Super Duty IQ GOLD 000 A
0 111006 $127
actual All Car and Truck Recycling - SCADA USA-CA(Anderson) Request_Quote 1-800-959-2552 Request_Insurance_Quote
1999
Fender
Ford Truck F350 Super Duty RH,Front, (w/o whl-lip mldg),TAN EXT X22433 $125 All Star Auto Recycling USA-CA(Corning) Request_Quote 1-530-824-2880 Request_Insurance_Quote
1999
Fender
1999
Fender
0 T3744 $150
1999
Fender
0 111006 $127
1999
Fender
SN95gts_Justin
01-19-2015 05:28 PM
IDIDieselJohn
01-16-2013 09:40 PM
jlegge007
24
07-17-2007 08:28 PM
