1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 hubs stuck
Old 06-02-2012, 01:49 PM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
05 hubs stuck
Alright the locking hubs on my 05 were in the lock position when I bought it. I couldn't get them to budge to rotate to the auto position. Today I got the hubs to rotate from lock to auto. So I figured I would take them apart and grease them, I did and they are stuck in auto position now. When they turned today they were very hard to turn. If I break the hub down and clean it will that help them?
Old 06-02-2012, 02:12 PM
2004 Ford F-250 v-10's Avatar
2004 Ford F-250 v-10 is offline
Spray some Wd-40 on the outside, handle is not connected to the internal parts of the hub, there is a rubber diaphram behind the handle, but that plastic handle gets crud in it makes it hard to turn, wd-40 works on my '04, work it back and forth and spray liberally, taking the hub apart will not help with the external handle.
Old 06-02-2012, 02:40 PM
mikeismadness
Thanks! I'll see what I can do
Old 06-02-2012, 07:41 PM
Post back if it works, I used pliers on mine until a buddy of mine gave me the wd-40 hint years ago as a result I've broken out the cast aluminum middle of the handle, but no water leaks so far, I do have to use manual all the time, but that's a separate issue and not a big deal for me, I really don't miss the auto lock although it was convenient when I had it, but not worth buying warns or mile marker replacements and still not having auto hub. There is a great link on here somewhere about taking your hubs apart and re greasing, pretty easy and if nothing else gives you an understanding how they work, it did for me anyway.
Old 06-02-2012, 10:58 PM
maverick22's Avatar
maverick22
maverick22 is offline
Keep in mind the 2005 hubs he's working on are not the same as your 2004. The 2005 and up hubs are technically not serviceable but here's a link on how to take them apart if you so choose. Definitely not as easy as the 99-04's. https://www.ford-trucks.com/forums/9...with-pics.html
Old 06-03-2012, 04:17 AM
Thanks for the link, guess I'll keep my opinion to my self on anything newer than 2005, lol.........uh yeah my hubs are way easier than those.
Old 06-03-2012, 07:54 PM
mikeismadness
Ya i found that thread thanks maverick22. I haven't picked up any wd40 yet, used the last of it on my squeaky fence gate last week haha.
Old 06-06-2012, 07:10 PM
mikeismadness
The WD40 trick worked excellent. Sprayed it right in the crack in between the **** and hub cover and twisted it with pliers at first and then did it by hand, now my hubs turn freely!
JoshC017
10-20-2016 12:09 PM
dmilam
06-10-2011 07:25 AM
phf2231
04-19-2010 05:33 PM
pmasley
39
10-16-2008 02:00 PM
FSSF
12-22-2007 04:18 PM
Quick Reply: 05 hubs stuck
