Getting the beast back together
Got my underbody tool boxes back on finally!
Boxing the stacks in with diamond plate. Not quite done, going to shorten the height a bit and put the top cover on at a slight slope to the back, then custom stack covers will be coming soon
My IC in place waiting for the lower brackets… and some time and $$ to get the bellowed uppipes in.
My IC pipes are goin to be wrapped with red exhaust wrap, I really like the look of a good wrap job.
Also got black headlight bezels and a new, rock guard deleo. The piece that goes below the grill and wraps around the sides a bit. Black of course.
The beast has only been down for a couple weeks but man I want this thing back on the road
Do u think wrapping the cold side will help keep the cool air " in" and keep the outside of the pipe from conducting any heat from the engine compartment.
I think when I get the bellowed uppipes I am goin to do the ceramic coating too. Shoot if I am spending $800 might as well throw another $100 at it. Lol.
My garage has parts and piece everywhere, the wife wants her navigator back in the garage. Ha ha ha
I know how that goes, parts and pieces from one end to the other. Just tell her you're gonna build a bigger garage then.
It won't hurt anything to wrap the cold side, but I don't think you will gain anything. There is a lot of air movement in the engine compartment. Heck, you got a big wide open air filter right there not worrying about under the hood heat.
When I finally get a new job in Washington state definitely getting a place with a big ol' shop. She is pretty cool with me and my 4 yr old making man messes. Lol. If I could just keep him from sneaking in the garage and messing with everything!!! He wants to work on the truck as much as I do. Ha ha ha. He loves watching videos of trucks rolling coal!!! He want to put pipes on his bicycle so he blow smoke on his little sister. I was cracking up when he told me that!!
That a brilliant idea. Accept he would dismantle the whole house. He found an Allen wrench and took the bolts out of his sisters bed. Don't ask me how he found the right size but he did. So i made him put them back in and he put them babies in tight. U can't turn your back for a minute!!!
With the ashtray I took out the metal liner case deleo and the 2 bolts that held it in place is what I used to mount the gauge pod. I had my welder put 2 tabs( one on either side) I drilled a hole in each and used them black push in thingys that are used to hold the inside door panels on. They hold real good and if I need to get in there just pop it out. Havent got to use the gauges since I put the pod in but it looks cool anyway. Lol
Well the new uppipes are in the turbo is back in place. Got my IC lower brackets made, just got to drill some holes to mount them. T-500 hpop is in and quick spool housing. Should have it completely together tomorrow and ready to go. FINALLY!! I will post some pics of the IC pipes when I am done.
