smog pump delete- now a squealing belt on startup...FIXED!!
  #31
Old 06-04-2012, 05:27 PM
materthegreater's Avatar
materthegreater
materthegreater is offline
Originally Posted by Midnite1987
my truck has the spreing tensioner. belt diagram on page 1. how is yours run?
i gutted my smog pump but i think i damaged it in the process it doesnt spin very good..
anyone know where i can find a idler to go inplace of the pump?
Here's what mine looks like. I didn't change the routing at all; just put the shorter belt in the same way as the old one, except without the smog pump in there.
  #32
Old 06-04-2012, 07:27 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
Yay!! No more squeak!!
Bought a 94.5" gatorback belt and routed it as factory just without the smog pump and she's nice n quiet now!
  #33
Old 06-04-2012, 07:45 PM
materthegreater
Nice! It's a good feeling when ya get something fixed, huh?
  #34
Old 06-04-2012, 07:56 PM
Midnite1987
sure is and this belt was only $18 lol now to bring the other three back and get my $90 back lol
and this one is a gatorback which everyone seems to say are the best
  #35
Old 08-15-2012, 01:10 PM
fosgate3's Avatar
fosgate3
fosgate3 is offline
Midnight, you did this on your 95 F150, with a 302, correct? I have a 95 w/302 and I want to do the same thing. My smog pump has crapped out.
  #36
Old 08-15-2012, 02:04 PM
Midnite1987
351 not 302. I'd imagine it's the same process just different belt
  #37
Old 10-15-2012, 05:32 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Just wanted to say thanks for the info, and following up with the correct belt length. Just ordered my belt, and I'll be doing this sometime this week.
  #38
Old 11-07-2012, 09:07 PM
amill's Avatar
amill
amill is offline
great thread, i'll be doing the same thing soon on my 96 5.0 bronco.
  #39
Old 11-07-2012, 09:39 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
the belt to use is an 88.8 for a 302
  #40
Old 11-08-2012, 06:45 AM
BigCheeseStick's Avatar
BigCheeseStick
BigCheeseStick is offline
Removed the smog pump on my '94 302 (originally had a 99" belt), and drove for three days just fine with the Gates 94.5" belt.. Within a week it started squealing on startup and QUICKLY got to where I couldn't turn on the heat or anything without it squealing. I ordered a Goodyear brand replacement tensioner because it has a steel pulley instead of plastic.. Actually squealed worse! Went to AutoZone and they let me try several belts until I found the one that fit PERFECTLY. The 94.5" belt fit, but the tensioner was maxed out allll the way. 93.7" juuuuust barely fit (NOTE: It's a MUST to install the belt on the tensioner pulley last because it's rounded edge) After a month of driving the tensioner is still dead center in it's travel limit. Works great, and is actually a cheaper, more common belt size than the 99", or the 94.5"
The cat was already removed and a true duel SS exhaust replaced it. I plugged the holes in the heads with JEGS Thermactor plugs, removed the vacuum hose from the TAD, TAB solenoids, and installed a 3" pc of 7/16" hose to bypass them completely. DID make a notable improvement in the truck just removing the pump. Not a LOT, but it's a bit smoother running now. And a month later I still don't have a single fault code on the tester. Total cost including the belt, plugs, and new tensioner.. About $60. Cheaper than they sell the lame "bypass bracket" for by itself. The whole engine bay is cleaner, and I can now change all 8 spark plugs with just the ratchet and socket. Not extensions or anything needed.
Note: you can remove and toss the Idler pulley as well!
"111" = Everythings good
  #41
Old 11-10-2012, 07:46 PM
amill's Avatar
amill
amill is offline
would you happen to have the part number for that belt?
  #42
Old 11-10-2012, 07:56 PM
amill's Avatar
amill
amill is offline
nevermind, i opened my eyes and saw it in the picture.
Thomscottson
02-13-2018 10:15 AM
sparr0
08-14-2015 10:04 PM
myakkacracka
07-03-2008 01:35 PM
frankyford
08-20-2006 06:27 AM
danielzink
1978 - 1996 Big Bronco
05-27-2005 01:28 AM
Quick Reply: smog pump delete- now a squealing belt on startup...FIXED!!
