DUAL BATTERY SET UP - Ford Truck Enthusiasts Forums
DUAL BATTERY SET UP
Old 06-01-2012, 04:37 PM
Matty Fraser's Avatar
Matty Fraser Matty Fraser is offline
Matty Fraser is starting off with a positive reputation.
DUAL BATTERY SET UP
I have two batteries set up operating at all times at the mo.
I want to put a dash board switch in.
I need a solenoid, switch, heavy guage wire. what else?
Anyone have a past link to step through an easy and straight forward set up.
Also, anyone buy recommended products in west coast canada.
Cheers!
Old 06-01-2012, 05:08 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
I want to put a dash board switch in. I need a solenoid, switch, heavy gauge wire. What else?
You'll need a continuous duty solenoid and wire terminals, a fuse and fuse holder to protect the switch, heat shrink, and zip ties.
Here are threads for your info: http://www.ford-trucks.com/forums/11...ry-wiring.html
http://www.ford-trucks.com/forums/10...-with-pix.html
... or get Painless Wiring's auxiliary battery wiring kit.
Old 06-01-2012, 09:10 PM
neondr neondr is offline
neondr is starting off with a positive reputation.
I would go with a battery isolator. Whole lot less trouble. Just my opinion.
Why would you want a manual switch? Just curious.
Super Duty Electrcal Problem HotDog88 1999 - 2003 7.3L Power Stroke Diesel 3 02-07-2016 06:12 PM
Adding "Custom Cab" Bling ihcc104 1961 - 1966 F-100 & Larger F-Series Trucks 1 12-20-2015 08:46 AM
Dual battery set up for 6.2 gas Flyingtexan1 1999 to 2016 Super Duty 5 10-26-2015 11:38 AM
Diehard battery charger, need some instructions please 78bigunns Garage & Workshop 5 11-18-2002 03:32 AM
Dual battery setup jon69f250 1967 - 1972 F-100 & Larger F-Series Trucks 5 09-17-2001 01:17 PM
Tags
1996, battery, box, bronco, diesel, dual, extra, f150, ford, kit, painless, series, setup, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
