Fe bore and stroke question
Old 05-05-2003, 10:25 PM
Andysutt's Avatar
Andysutt
Andysutt is offline
I just tore down what i thought was my 390...
Im making sure its a true 390... please could someone post a list of what bore and strokes make what?
I ordered a thousand dollars worth of parts for the truck last nite, and tore it down today...
All I have to do now is buy rings/bearings/pistons and I wanna make sure before I buy them
Please let me know..
Old 05-05-2003, 10:36 PM
Jsbiohazard's Avatar
Jsbiohazard
Jsbiohazard is offline
standard 390 bore is 4.050 and stroke is 3.78"
standard 360 bore is 4.050 and stroke is 3.50"
standard 352 bore is 4.000 and stroke is 3.50"
standard 410 bore is 4.050 and stroke is 3.98
standard 428 bore is 4.130 and stroke is 3.98
Measure the stroke first to be sure which crank you have. If it is not 3.78" then it is probably a 360 or 352. Good luck!!
Old 05-06-2003, 05:25 AM
Andysutt's Avatar
Andysutt
Andysutt is offline
Thank God! It is a 390
My friend measured one of the cylinders w/ the head off of it last nite... 3 3/4 he said roughly
Thanks for the info, I appreciate it greatly
Old 05-06-2003, 11:07 AM
Mike G's Avatar
Mike G
Mike G is offline
Andy:
Since you are in it that far, jot us down the crank number and we'll help you set your mind at ease...
--MG
Old 05-06-2003, 02:33 PM
Andysutt's Avatar
Andysutt
Andysutt is offline
I will do... as soon as I get that far
I built a matching set of heads for it C6Ae-R's I think... (forgot off top of my head)
Mine had mismatched heads and these heads are really nice so I used them.
They are ported and has a valve job.
Anyways, I'll let you know when I take the oil pan off and remove the pistons and such
Im sure its a 390 now tho, but just to make sure
fluidp
12-14-2014 03:34 PM
pboffroad
07-08-2013 02:39 PM
77_F150_4x4
11-19-2007 10:58 PM
wiles1947
07-19-2006 01:08 AM
Quick Reply: Fe bore and stroke question
