Fe bore and stroke question - Ford Truck Enthusiasts Forums
Old 05-05-2003, 11:25 PM
Andysutt's Avatar
Andysutt Andysutt is offline
Andysutt is starting off with a positive reputation.
I just tore down what i thought was my 390...
Im making sure its a true 390... please could someone post a list of what bore and strokes make what?
I ordered a thousand dollars worth of parts for the truck last nite, and tore it down today...
All I have to do now is buy rings/bearings/pistons and I wanna make sure before I buy them
Please let me know..
Old 05-05-2003, 11:36 PM
Jsbiohazard Jsbiohazard is offline
Jsbiohazard is starting off with a positive reputation.
standard 390 bore is 4.050 and stroke is 3.78"
standard 360 bore is 4.050 and stroke is 3.50"
standard 352 bore is 4.000 and stroke is 3.50"
standard 410 bore is 4.050 and stroke is 3.98
standard 428 bore is 4.130 and stroke is 3.98
Measure the stroke first to be sure which crank you have. If it is not 3.78" then it is probably a 360 or 352. Good luck!!
Old 05-06-2003, 06:25 AM
Andysutt's Avatar
Thank God! It is a 390
My friend measured one of the cylinders w/ the head off of it last nite... 3 3/4 he said roughly
Thanks for the info, I appreciate it greatly
Old 05-06-2003, 12:07 PM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
Andy:
Since you are in it that far, jot us down the crank number and we'll help you set your mind at ease...
--MG
Old 05-06-2003, 03:33 PM
Andysutt's Avatar
I will do... as soon as I get that far
I built a matching set of heads for it C6Ae-R's I think... (forgot off top of my head)
Mine had mismatched heads and these heads are really nice so I used them.
They are ported and has a valve job.
Anyways, I'll let you know when I take the oil pan off and remove the pistons and such
Im sure its a 390 now tho, but just to make sure
410FE??? greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-03-2015 10:27 AM
stroking out a 352 block fluidp FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 12-14-2014 04:34 PM
bored over is bigger better ?? pboffroad 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-08-2013 03:39 PM
Bore and stroke... 77_F150_4x4 Performance & General Engine Building 10 11-19-2007 11:58 PM
370ci 385 series wiles1947 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 07-19-2006 02:08 AM
Tags
1966, 352, 360, 390, 390428, 428, big, block, bore, bores, fe, ford, stroke, strokes, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
