engine codes - Ford Truck Enthusiasts Forums
engine codes
Old 06-01-2012, 02:23 PM
jurban's Avatar
jurban jurban is offline
jurban is starting off with a positive reputation.
engine codes
Can you help diagnose my codes, Im getting a lot of sputtering, I installed jumper wire in the diagnostic ports and got a code 6,7,6,7 it paused for like 9 seconds and then gave a string of codes 1,1,4,3,1,4,1,8,7,9,6. I then did the engine running test, it flashed 3 times (indicating the 6 cylinder) I then cranked the steering wheel, but saw no flash to press the gas pedal and it displayed no codes after that. Its a 1989 f150, 6 cyl and a 5 speed
F150 won't give codes! Stikky_Nuttz Computer Chips & Tuners 2 03-12-2015 12:52 PM
03 explorer 4wd high 10 times blinking 03explorer23 Explorer, Sport Trac, Mountaineer & Aviator 6 02-03-2015 11:55 AM
'93 5.8 interpreting engine diagnostic codes tabijan 1968-2013 Full Size Vans 7 11-19-2012 10:23 PM
Code Meanings-Chilton Book SideWinder4.9l 1987 - 1996 F150 & Larger F-Series Trucks 0 02-22-2011 08:15 PM
2002 glow plug check engine codes? rblaine9000 1999 - 2003 7.3L Power Stroke Diesel 2 02-08-2011 08:36 PM
Tags
29, 351w, code, engine, ford, odb, trouble, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
