Rear drum brakes won't go back on
Old 06-01-2012, 08:29 AM
bloydj's Avatar
bloydj
bloydj is offline
77f100 2wd
I replaced brake cylinder after I found a stripped bleeder valve on right rear (replaced both rear cylinders). The problem is that I can't get the drums back on.
Adjusting screw is all the way in but can't get drums on. When I took out adjusting screw the drum went on. Top of shoes seem to be seated correctly. Any troubleshooting suggestions are greatly appreciated.
After looking at other threads, common issues that cause the drum not to go back on is
1. Adjusting screw not fully in
2. Brake cylinder pistons not in causing shoes to push out
For 1, the adjusting screw is fully in and for 2, the pads look like they are fully seated.
Please help me figure out how to get the drums back on. Thanks
Old 06-02-2012, 07:41 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
A common issue is with the parking brake. Make sure the parking brake is fully off, that the cables are not sticking and that the parking brake linkage inside the drum is free. Make sure the shoes are properly seated in the parking brake mechanism.
Old 06-05-2012, 11:44 AM
bloydj's Avatar
bloydj
bloydj is offline
I installed the adjuster in the wrong spot. I put it on the tips of the brake shoes instead of up a bit where the grooves are perpendicular to the ground. I'm an idiot. I will never make that mistake again though. Drums slid right back on and the tires are back on the truck.
thanks for your help.
One Sock
05-30-2023 08:42 AM
harleyfan1
04-25-2011 04:08 PM
Level2
1983 - 2012 Ranger & B-Series
15
10-03-2008 07:47 PM
Jupiter Coyote
1997 - 2003 F150
05-03-2004 05:30 PM
cbmark
1997-2006 Expedition & Navigator
12-06-2003 11:40 AM
Quick Reply: Rear drum brakes won't go back on
