Which tires for towing 14k 5th wheel? - Ford Truck Enthusiasts Forums
Old 06-01-2012, 12:02 AM
Van Diemen's Avatar
Van Diemen Van Diemen is offline
Van Diemen is starting off with a positive reputation.
Our 5th wheel Toy Hauler is about 14k # when loaded up. The Truck is an '06 F-350 CC LB 6.0 with the OEM 20" Ford aluminum wheels and Goodyear Wrangler AT/s tires.
I know the 20" wheels are not the best for towing. Also I've had TWO wheels crack and TWO blowouts. I'm not pressing my luck any longer with these wheels and replacing with 18".
You can check out the cracked wheel post here....
http://www.ford-trucks.com/forums/10...l-cracked.html
The Goodyear AT/s are the OEM tire and I've always just replaced them. I'm on my 5th set in 175,000 miles. Time for a change as well. Haven't had good wear out of the Goodyears along with 2 front blowouts.
I was thinking of trying the Michelin LTX AT/2's E rated. They get high reviews. Just don't know how they handle towing heavy.
What are you haulers running?
Old 06-01-2012, 01:24 AM
onug's Avatar
onug onug is online now
onug is gaining momentum as a positive member of FTE.onug is gaining momentum as a positive member of FTE.
I replaced my stock Conticraps about 10K miles ago with Michelin LTX M/S-2's on my factory 18" rims. Love the new tires in every way. With the 70K mile guarantee, you can't go wrong. My F-in-L got the ATs on his 2012 SD and I swear they're already at 50% and he doesn't tow anything. I've never had them, but I'm not so sure they'll hold up very well with a heavy 5th wheel.
Old 06-02-2012, 12:46 AM
P.Bronner P.Bronner is offline
P.Bronner is gaining momentum as a positive member of FTE.
How big is your trailer, and do you have a verifiable pin weight for it- not a guesstimate. If you're cracking wheels and blowing tires, I suspect its considerably heavier than you think it is. I have 18x8 factory rims and am running Toyo Open Country A/T's size LT 285/75R18E rated at 4040lb. per tire. I have a 2750 lb. pin plus usually haul 10 gal extra fuel and typical camping crap/tools in the back and these tires don't even get noticeably warm. Zero problems with them and good tread life. I have another set in M/T tread for the winter.
Old 06-02-2012, 07:39 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I recommend Coopers. I have had them on two trucks and run them on my cars as well.
I have the discovery STT's. Probably more aggressive then you are after but I off road and snow and stuff.
The thing I like is even heavy towing cross country I will feel my tires at fuel stops and they are not hot at all.
So a great towing tire. E-rated as well. Look into something that cooper makes.
Oh..I come in right at 14K on my 5er.
Old 06-11-2012, 01:10 AM
RadRick RadRick is offline
RadRick is starting off with a positive reputation.
Just my $.02, but I agree with what onug said above, if you are going with Michelin stick with the LTX M/S-2's. I had the original LTX M/S on my 1999 F-350, 265/75-16's and they worked great pulling my 40' 16k# toyhauler. The problem with the Michelins is they start cracking before you can wear them out, so mine still had about 10% tread left when I replaced them with the same size LTX-A/T-2. These tires drive great empty, but when I hooked up the trailer they had so much tread squirm I pulled over because I thought I was getting a flat. It was a white knuckle ride the whole way.
Luckily (?) these tires wear really fast, so after a couple thousand miles everything was back to normal. I doubt these will make it 30,000 miles towing, and when pulling a grade you can just hear the rubber shearing off them. On the other hand the year I got them we had more snow than I've ever seen here before, and they were unstopable, I was plowing through the stuff like it was nothing.
But next time I will go back to the LTX M/S-2's for sure.
Old 06-18-2012, 03:05 PM
AGE mechanic AGE mechanic is offline
AGE mechanic is gaining momentum as a positive member of FTE.
I just had the Nitto Crosstek HD installed this weekend. Haven't towed anything but they look like a great tire. I was going to go with the Mich. LTX M/S-2's, but they are up there in price.
'06 F-350 20" OEM wheel cracked !?!?! Van Diemen 1999 to 2016 Super Duty 50 04-06-2016 03:15 PM
2008 F250 Tire Replacement Finnlander 1999 to 2016 Super Duty 2 02-21-2013 09:07 AM
Towing 14K with an '06 F-350 6.0 LB CC SRW 4x4? Van Diemen Toy Hauler Towing; Fifth Wheel & Bumper Pull 7 08-10-2010 03:44 PM
Upgraded 20" tires on my '08 F250 PSD 4x4 - Michelin LTX A/T 2 Champ198 6.4L Power Stroke Diesel 2 12-15-2009 08:34 PM
Blowout under load StanleyZ Fifth Wheel & Gooseneck RV Towing 8 10-15-2008 08:13 PM
Tags
14k, 5th, ats, f250, goodyear, om, pound, pulling, rated, reviews, standard, tire, tires, towing, truck, wheel, wrangler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
