Vermont June BS - fun in the sun and lots of warmBS
#1502
on
Good evening Joe, Don and Rick.
Have a safe flight and enjoy the plane ac
Excursion is running. Last fall I lost the original key and had to get new one programmed. Well found the original last Friday. I thought the programming between the old and new would be the same. Its not. The truck thought it was being stolen so it went into anti theft and disabled the ignition. Git the new key and started up.
#1504
That was an easy fix
#1507
#1511
on
A guy I know that owns his own garage brought his snap on scanner and hooked it up. First code was anti theft disabled
I don't other than the house should be cooler than outdoors. Maybe a thermal switch no good so furnace doesn't know to turn on and blow?
#1513
