std cab long bed/supercab short bed. Same WB?
They are different. But it can be done.
Here's a thread on wheel bases.
https://www.ford-trucks.com/forums/8...s-covered.html
I would make it a 133 wheel base super cab. Just make some new rear mounts that will line up with the cab then measure how much you will need to take out of the bed to make it match up.
Or you can cut the frame and put the 4wd front on the 2wd rear. But that is a lot of work and precision.
JakRak
06-07-2018 08:50 PM
