Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 05-12-2003, 05:05 PM
PSKSAM2's Avatar
PSKSAM2 PSKSAM2 is offline
PSKSAM2 is gaining momentum as a positive member of FTE. PSKSAM2 is gaining momentum as a positive member of FTE.
New Double Platinum Plugs and Wires
Quote:
Originally posted by Bob Ayers
Hi Jim,
What you are suggesting would extend the life on single platinum
plugs. One thing to notice, however. If you pay close attention to
the OEM Motorcraft plugs, they are single platinum!! But, the plugs in one bank have a different letter suffix in the P/N than the
plugs in the other bank. This is because the outer electrode is
platinum on one plug P/N, while the center electrode is platinum
in the other plug P/N.....So, if the plugs are pulled, and
re-installed, it's important to put the plugs back into the same
bank that they came out of.....
Bob,
Did you mean to say in your first sentence that swapping the plugs from one bank to the other would extend life on double platinums? Otherwise I'm confused. That's interesting that they put two different parts into the motors. Oh well.
-Jim
__________________
02 Mustang GT
98 B4000 SE 4 4x4 Auto
No single raindrop feels that it is responsible for the flood.
  #17 (permalink)
Old 05-13-2003, 06:25 AM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE. Bob Ayers has a good reputation on FTE.
Quote:
Originally posted by PSKSAM2
Bob,
-Jim
Hi Jim,
I guess I wasn't very clear. No, switching single platinum (only the
center electrode is platinum) will extend the plug life some.
  #18 (permalink)
Old 05-13-2003, 05:20 PM
PSKSAM2's Avatar
Hi Jim,
I can see how you could eek a little more life out of the singles by swapping them. If you had them in correctly at first, and had worn down the platinum electrodes, you could now wear down the non-platinums. Or if you had installed one side correctly, and the other with the same single platinums, you could swap so that the ones that wore wrong are now on the correct side and wearing down the platinum while the originally correct ones will have their chance to wear down the non-platinum side.
I see what you are saying now. But you are saying that there would be no advantage to swapping the double plats, cause they don't wear much at all?
__________________
02 Mustang GT
  #19 (permalink)
Old 05-14-2003, 06:27 AM
Yes, since both electrodes have double platinum, then both
electrodes are going to erode at the same rate (very little),
so there is no point in swapping them....
  #20 (permalink)
Old 05-15-2003, 08:07 AM
PSKSAM2's Avatar
Got it! Thanks, good discussion!
__________________
02 Mustang GT
  #21 (permalink)
Old 05-15-2003, 01:42 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
I don't know anymore. I spend sometime at a site that has a lot of Ford mechanics and they all say Autolites are crap and they are worse then Bosch.
Quote:
Originally posted by rockledge
Interesting. I just heard the same thing, myself. That's probably why so many people have had good luck putting Autolites in their Ford motors. I've been hanging around the the Ranger Forum for a while and like I said a lot of guys have installed the Autolite DP's in their 4.0Ls and have reported very good results.
  #22 (permalink)
Old 06-26-2003, 12:21 AM
jcandrew jcandrew is offline
jcandrew is starting off with a positive reputation.
For my Ford Ranger with the 3.0 L the manual recommends AFSF22PP. I bought these Motorcraft plugs at Autozone for a great buy thanks to your posts. Are these double platinum plugs? Just double checking... get it? "double"
__________________
'00 Ranger XL TrailHead 4X2, 3.0L FFV
  #23 (permalink)
Old 06-26-2003, 06:21 AM
Quote:
I think you meant AGSF22PP, instead of AFSF22PP. Yes, they
are double platinum.
  #24 (permalink)
Old 06-26-2003, 10:10 AM
Thanks Bob, you are right. I did mean the AGSF22PP. Good to know for sure that these are the double platinum.
__________________
  #25 (permalink)
Old 06-28-2003, 09:51 AM
Quick question about plug installation: Do you guys ever put "never seize" or simply a few drops of oil on the new spark plug threads so they don't squeak so much upon installation? What do you think?...
__________________
  #26 (permalink)
Old 06-28-2003, 10:50 AM
Yes, a small amount of "anti seize" on the threads, and
dielectric grease inside of the spark plug boots.
  #27 (permalink)
Old 06-28-2003, 10:59 PM
Sounds like a good plan. Thanks for the quick reply Bob!
__________________
  #28 (permalink)
Old 08-26-2003, 10:42 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
Another relevant thread regarding spark plugs here: Debunking the Myths of Bosch Platinum Plugs
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #29 (permalink)
Old 08-30-2003, 10:22 PM
Edge02Ranger4x4 Edge02Ranger4x4 is offline
Edge02Ranger4x4 is starting off with a positive reputation.
The 3.0 Has 2 different plugs in it, when i install new ones, can i just install all double platinums (AGSF22PP), or what??
  #30 (permalink)
Old 08-31-2003, 12:18 AM
Rockledge's Avatar
Edge02Ranger4x4,
Yes you can put in the double platinums, and in fact, that is what Ford calls for when you replace the original factory plugs. One of the main reasons that double platinum plugs are recommended as replacements is so that they can be installed without worrying about mixing and matching...
P. S. Welcome to Ford truck Enthusiasts!
__________________
Ford Pics
Tags
agsf22p , agsf22pg , autolite , awsf32p , awsf32pg , bosch , double , dual , flex , motorcraft , ngk , platinum , plug , plugwaste , reviews , spark , verses
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
