Tire pressure 32x11.5
That sounds like an awful narrow wheel for that size tire, to me. Here is what I did when I ran 33x12.50-15's on ten inch wheels on my '88.
Start with the tires fully inflated to the rated max. Go to an empty paved parking lot and make a mark across the tread with tire chalk. roll the truck forward enough to see how flat the tread is on the ground. Adjust air pressure until the chalk is removed across the width of the tire.
You will probably end up at something like 28-30 pounds. I usually ran about two pounds more in the front, due to the weight of the engine. When you need to haul something, air the tires up so you don't get too much flex and heat build up.
I have done this on all of the trucks I have ran larger than stock tires on for the last thirty years and haven't had a problem yet.
I got the idea from a Hot Rod magazine article about running wide tires on musclecars about 1980.
Robert
Robert
I have 33x12.50x15 on my truck. 35 pounds. Summer, winter. Highway, city. All the same. Thats probably the safest bet. The only downside is that since they are so wide and the wheel is so narrow, it eats the center of the tire no matter what the pressure.
What im saying is, run at 35 and that narrower size tire will be fine on those wheels.
Thanks for the advice guys. I know the tires are a little pinched on those narrow rims. I figured they would wear out in center quicker due to this. I drove across a fine gravel parking lot and
only the center of tire was
getting dirty at 42 lbs. I've
dropped pressure down to
35 to get more tire on road. I
couldn't pass up the deal on
these tires. Practically brand new BFg all terrain for $50 a piece on Craigslist. Sweet
on
I've got the same size tires on my stock 7.5" rims too and I run 'em at 45 lbs. I have BFG A/Ts as well, which have pretty blocky tread at the corners, so if the inflation/rim size raises the edges a bit, that is OK because it will make the tire quieter. So far I have not seen a problem with wear in the center like you are concerned over - I've got about 20K miles on them. I had the same size tires on my Bronco (Michelins) on the same rims and they went 90K miles.
djeclipse
1983 - 2012 Ranger & B-Series
06-27-2005 01:07 AM
jetjock16
1999 to 2016 Super Duty
11-12-2002 09:16 PM
f150cobrajet
10-22-2002 07:20 AM
