Can't find coolant leak - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 05-31-2012, 12:57 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
I've noticed recently a small wet spot of coolant under the truck after I've been stopped a while and I'll be darned if I can't find where it's coming from. I've crawled around underneath with a flashlight and I can see that it seems to be coming from the back of the engine, maybe the drivers side, but there's no way to actually see that area directly. There's just no room behind the engine to get a look and there's so much other stuff in the way...
Looking at the shop manual isn't helping. It doesn't show any coolant hoses in this area, and I can't even tell if there are freeze plugs that might be leaking. There isn't any coolant in the oil (than I can tell), and it isn't leaking very much. It's just enough to make the bell housing wet and leave a wet spot on the ground. FWIW, the truck has 102,000 miles and runs good.
Can anyone tell me where this coolant might be coming from? I'd hate to take this to a mechanic and give them permission to do exploratory surgery. They could make up anything they wanted and I wouldn't be able to tell if they're wrong or right.
Old 05-31-2012, 01:47 PM
ranger pat's Avatar
ranger pat ranger pat is online now
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Most auto supply stores will loan you a coolant pressure tester. It connects to the coolant system and you pump up the pressure with a small hand pump. The pressurized coolant will then seep out of any leak in the hoses or engine and you will be able to visually identify where the leak is coming from.
Old 05-31-2012, 08:28 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Check up top. It could be leaking from the intake area, running back and down. Using a small mirror will help to see the back of the motor.
Old 06-01-2012, 04:30 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
If your smelling coolant in the cab, & the ground leak spot is back under the middle of the firewall, you could have a heater core leak thats dripping out the lower firewall AC condensate rubber drain tube
Might be helpful if we knew which engine you have.
Old 06-01-2012, 02:21 PM
Thanks for the suggestions.
I've checked the intake (as much as I can see) and didn't see the leak. The problem is visibility. Actually, I don't think that the 4.0 has any coolant going through that plastic intake manifold, anyway....
Unfortunately, the pressure tester won't help. I already know I have a leak. The problem is being able to see where it's coming from. If I could open a door in the firewall and peer thru from inside...
Pawpaw, I'm not smelling coolant in the cab. Having had bad heater cores in the past, I'm familiar with that smell. It would fog the windshield, too. But the heater is on the right and my leak seems to be on the left. I'll have to add the engine size to my sig (but it does say FX4).
Does anyone know if the 4.0 engine has freeze plugs? I couldn't find any reference to them in the shop manual. If not freeze plugs, do these engines leak from the head gasket? I jacked up the truck this morning and tried looking in from the drivers side wheel well. I could see that the split line between the head & block looked wet ( ), but I can't rule out the possibility that it came from above. Although I don't know of any coolant lines above this area.
Old 06-01-2012, 09:55 PM
I don't have the OHC 4.0L, so I really can't speak to it with any first hand expierence, but I haven't heard of any perstant problems with the OHC engine after about 01, when they got the chain tensioner problem worked out, unlike problems we had with the pushrod 4.0L lower intake manafold & head gasket leaks.
Old 06-02-2012, 11:46 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
The pressure will make the leak easier to spot.
Old 06-13-2012, 09:23 PM
Finally found the leak source. I took it to the dealer and they couldn't find it at first. So they removed the intake manifold to search under there and then they were able to see the leak at the back of the head, coming from a hole that is used to suspend a wiring harness support. Apparently, the hole had gotten drilled a bit too deep at the factory and broke into a cooling passage. Sealing the bolt was easy. Why it took eight years to start leaking is a mystery that will never be solved, but I'm glad that they didn't have to pull the head to find or fix the leak.
Old 06-13-2012, 09:46 PM
Quote:
Good find, fix, & feedback. Give the Dealer an attaboy, for finding & fixing that one!!!!
Old 06-21-2012, 09:24 PM
bazzman1953's Avatar
bazzman1953 bazzman1953 is offline
bazzman1953 is starting off with a positive reputation.
Ditto to Pawpaw. Nice to have a close on a question. I still have a problem that I haven't solved so I can't close it. So thanks!
2004 Navigator slight coolant leak MackGuy 1997-2006 Expedition & Navigator 38 01-04-2017 10:22 AM
Coolant leak on drivers side rear of the motor Kdawg89 6.0L Power Stroke Diesel 3 09-07-2015 09:25 PM
2001 Sudden Coolant leak stang99gtv8 1997 - 2003 F150 5 07-01-2015 12:44 PM
Ellusive oil leak wildwest2 6.0L Power Stroke Diesel 1 11-04-2014 07:34 PM
Update on 4.6L Intake Manifold related water leak guitar_199 1997 - 2003 F150 1 10-18-2010 07:34 PM
Tags
150, 2006, 46, 58, antifreeze, caant, coolant, coolent, duty, f250, find, ford, leak, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
