2003 F150 FX4 need ac help in a bad kind of way! - Ford Truck Enthusiasts Forums
Old 05-31-2012, 01:07 PM
Rcurry2069 Rcurry2069 is offline
Rcurry2069 is starting off with a positive reputation.
Ok guys, I'm new to the forum, and have read a few things and really like what y'all have going here. I have a 2003 Model F150 4x4 that has always ran good for me, and has only had minor issues ever since I've had it. Not too bad considering it has 266,xxx miles on it and running 100 miles a day on the original motor & transmission.
Here's my problem - my air conditioning will only blow thru the defrost. I can hit vent on the control panel and it will blow thru the vents, but if i hit max ac it switches to defrost. I live close to Memphis, and it has gotten super hot around here and i really need this to work correctly. I'm hoping a little advice from y'all could help, bc a shop will cost me an arm and a leg. I'm not very knowledgeable about this stuff (have worked more on older vehicles) so i guess i'll need a fairly detailed reply if possible. I have looked under the hood looking for messed up vacuum lines but haven't seen any that looked bad.
Please help if you can and thank you for reading!
Old 05-31-2012, 01:54 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Have your AC tested for PSI. It may need a additional charge of refrig espacially if you have never had it serviced. My 2003 needed about a half can a couple years ago. Check your codes for EATC failure related vacuum door problems. O-ring failure can bring about failure of the doors. check the Vacuum system for leaks. Low vacuum will affect operation of the doors. If you find a vacuum leak, fix it. You can get a can of refrig with a gauge on it. Fill your low pressure side to specs making sure about the temperature of outside air/PSI ratio. You can purchase a rebuilt air temp cantrol unit but replacing it, you may need some help. Internally the o-rings may be damaged leaking across. Getting the Refrig back up to PSI may help you for sometime and finding a Vacuum leak will save you lots of $$$$'s
Old 05-31-2012, 02:46 PM
Well it still blows very good on vent thru the vents, and also blows very good thru the defrost (even when the max ac is selected)
Old 05-31-2012, 02:48 PM
And it does need a little freon i would imagine bc at a stoplight, it won't blow quite as cold. This shouldn't effect the vent system though should it?
Old 05-31-2012, 05:53 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
location of the air has nothing to do with freon. There are 3-4 little vacuum cylinders that stroke doors inside the duct and route the air to the defrost, vents, floor, or combo. If you loose vacuum to the system, then the default is to go to defrost. You need to check the heater also. Can you put air to the floor, and vents, or always defrost. If if just screws up on "max ac" , then you probalby have a leak on that hose or cylinder for the "cab recirc door". The loss of vacuum causes the other doors to go to defrost.
Old 05-31-2012, 05:54 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You can get a head start by going to the section of the forum dedicated to HVAC systems and reading the FAQs there.
Old 05-31-2012, 05:55 PM
steve(ill)'s Avatar
Old 06-01-2012, 08:17 AM
If i hit floor, it goes to defrost as well, but if i hit vent it blows thru the vents like its supposed to
2003 expedition a/c blowing thru deforst not thru vents 150Rob 1997-2006 Expedition & Navigator 5 04-01-2016 10:22 AM
2003 F150 FX4 need ac help in a bad kind of way! Rcurry2069 Cooling, Heating, Ventilation & A/C 1 05-31-2012 07:52 PM
2003 f250 6.0 diesel a/c problem claycomotrucks1991 Cooling, Heating, Ventilation & A/C 22 05-29-2009 12:02 PM
2003 ac unit removal for defrost venting ladon4893 Cooling, Heating, Ventilation & A/C 1 06-06-2007 01:37 PM
A/C blows thru defrost vents? tigerdude2001 1987 - 1996 F150 & Larger F-Series Trucks 7 12-16-2001 03:10 PM
Tags
03, 2003, ac, charge, defrost, door, f150, ford, freon, fx4, max, psi, refrigerant, system, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
