Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-31-2012, 10:52 AM
56 ford custom's Avatar
56 ford custom 56 ford custom is offline
Garage is empty, add now
56 ford custom is starting off with a positive reputation.
1960 f100 installing new motor/trans mounts
So I am replacing all the mounts since everything is torn apart. I havent touched the truck in a while and now I cant remember how it all goes together. Can somebody please walk me through it? Here is a pic. The old on the left and new on the right. Thimk im missing the two small donuts for up front.
Click the image to open in full size.
  #2 (permalink)
Old 05-31-2012, 06:40 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Yeh, looks like you are missing the upper fronts, the old pieces that are still on your front mounting bolts.
  #3 (permalink)
Old 05-31-2012, 06:47 PM
truck
Ok well I just boutght them a few houra ago on my lunch. So how do all of these go back together now?
  #4 (permalink)
Old 05-31-2012, 08:16 PM
truck
Im going to try and get the motor and trans in tonight so if somebody can point me in the right direction on how exactly the bushings go in and what not. Thanks
  #5 (permalink)
Old 05-31-2012, 08:35 PM
spurredon's Avatar
Well, I told you wrong on the parts you were missing. the smaller round ones that you still need are the lower fronts. The go under neath the bracket on the frame in the front of the engine. the taller round ones go above the frame bracket and below the bracket coming off the bottom of the engine. you will see how they fit into the aprox. inch hole. The bottom one fits around the top one where it sticks thru! Clear as mud yet? Then your bolt runs thru all this with a nut and washers on the top side of the engine bracket.
In the rear, the smaller rectangle piece goes on the bottom side of the big 'ol cross member. the ticker rectangle piece goes above the cross member and under the rear foot of the bell housing. If I remember right the top piece sort of stradles the cross member. Then after you put a bolt up thru a nut and washers go on top of the bellhousing foot.
I'm not much of a tech. writer but I believe I told you straight. Have fun!
  #6 (permalink)
Old 05-31-2012, 09:29 PM
truck
Somebody has got to have some pics!! I am a visual learner lol
  #7 (permalink)
Old 06-02-2012, 02:07 PM
truck
For the front mounts...does the bolt slide down from the top and nut on bottom or opposite way?
Tags
1957, 1960, 292, 429, engine, f100, ford, install, mount, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
