Average cost of paint job? what range have you paid? - Ford Truck Enthusiasts Forums
Old 05-31-2012, 07:48 AM
bryanknie's Avatar
bryanknie bryanknie is offline
bryanknie has a good reputation on FTE.bryanknie has a good reputation on FTE.
Truck is a 1952 F1. What is the range to expect for the following job, including dissasembly and reasembly.
Only needs about 3 spots the size of a cell phone that needs rust repair/new metal welded in. on on each rear fender where it meets the running board and on on the passenger door, other wise truck is real solid.
Cab will be painted frame on but will be totaly striped of all glass rubber, doors, gauges etc.
All other body panels will come off to be painted, including bed. No total stipping/sandblastng will be needed, just in any problem areas.
Over all I am looking for a nice driver paint job, base coat with non metalic paint and clear coat, ie a new car quality job, not a show job that is color sanded etc.
Just looking for some ranges, ie what you did and what was the cost vs quality
Old 05-31-2012, 08:59 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Too many variables to guess....Depends on what you want and how much of the work you are willing to do.
Body shops charge $50-$100 per hour for labor, which adds up quick. Good quality materials for the job will be $1000 plus......
My best suggestion is find a shop/painter that is HONEST and won't jerk you around. Get references.
You get what you pay for......
Old 05-31-2012, 09:13 AM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
I haven't had my truck done but I did have the Mustang done just as you described. The car was basicily a shell when it went to the painter and had very minor rust spots the were repaired with metal. They did strip the old paint down to bare metal. The job was a base coat /clear coat. it cost 7K. I am doing the body work on my 48 myself, hoping to save a few bucks.
Old 05-31-2012, 10:10 AM
cruisetopdown's Avatar
cruisetopdown cruisetopdown is offline
cruisetopdown has a good reputation on FTE.cruisetopdown has a good reputation on FTE.
Years ago I had a friend that owned a body shop that let me rent his downdraft booth for $75.00. I painted my Fathers 67 Mustang Fastback on a Sat. when they were not busy....My Father asked the painter (who had just stopped in to pick up some tools) how much his paint job would have cost if it was run through the shop, he looked it over and casually said "about 8 grand just for the paint job" .... I think my dad coughed up his left n*t on that one
Tinman is right in that you will want to research your area for a reputable shop, have them tell you their processes, what brands of materials they will use, etc..... just remember "you get what you pay for"
Best of luck,
w
Old 05-31-2012, 10:44 AM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
There are a lot of experienced folks on this forum who could go into great detail on this topic but if you are really looking for revelant info then your best bet is to take the truck to a few local shops for estimates.
Here's an interesting story that shows how prices can vary...a local father/son shop works on quite a few Corvettes. The Corvette crowd is used to paying through the nose for any work or parts so price isn't usually an issue. BUT...the old man has been stripping paint on these fiberglass bodies for so long that he can do a complete car in less than a day. Did I mention he uses a single edge razor blade? To the point, his labor for this task is a few hundred dollars and materials amount to pocket change. This same job in another shop would cost thousands.
Find a local guy who can explain the process in terms of hours and skill level. Have him lay out the cost of materials and explain the value of one brand/product over another. Most shops use only one brand because they know their product line and have a lower risk of failure if they use the same product over and over. If you are getting a BC.CC job then be sure to have them spray an additional coat of clear, it won't coat that much more and it will insure that you have plenty of paint to work with when you later choose to colorsand and buff.
Old 05-31-2012, 11:16 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
You'll likely be paying for a lot of frustration and "ugly work" that is common when disassembling these trucks, frozen bolts, etc. If he's doing re-assembly then he'll want all new hardware/rubber on the bed, glass, and such, so your costs will include that stuff. That kind of work is much more in the "restoration shop" scope of work than a paint and body shop trying to push jobs through the shop as fast as possible. You're easily in the $10k+ range IMO.
Old 05-31-2012, 11:33 AM
SanDiego56 SanDiego56 is offline
SanDiego56 is starting off with a positive reputation.
Charlie, do you have any recommendations for shops in San Diego area?
Old 05-31-2012, 11:49 AM
CharlieLed's Avatar
Quote:
Since I do all my own work I don't have a feel for a broad spectrum of shops in this area. SoCal in Santee does very professional show-quality work with a corresponding price tag. Jerry Goulet has his own shop off I8 on the south end of Lakeside...Jerry used to work for SoCal and then opened his own shop. Same quality as SoCal at less cost. Then there is always Jack White, he's out in Campo/Lake Morena area...many old-timers swear by Jack and for good reason. All these shops are top-shelf so don't expect to get a Maaco price quote from them...but if you want quality then any of the three would work.
Old 05-31-2012, 01:23 PM
ben73058's Avatar
ben73058 ben73058 is online now
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Bryan,
I've been wondering what your truck looks like now - that would help with guesstimates on Paint, etc. My truck below was sandlblasted & totally disassembled for painting - $7K is in the ballpark for the cost.
If you just want a truck that looks ok - you should be able to do $2K to $3K - it would be best if you do the prep work up front. It's a can of worms when they start fixing rust & grinding away - it can add up in a hurry.
Good luck over there - show us what your truck looks like as it sits now.
(We lived in Ft. lauderdale for 7 years - nice once all the tourists go home).
Ben in Austin
Old 05-31-2012, 01:30 PM
Stephen67's Avatar
Stephen67 Stephen67 is online now
Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.
I like to paint things myself, I can tell you the cost of materials is at least $1000. You spend $100s on just sand paper believe it or not.
The way I saw it was I could learn to paint, even screw up half a dozen times and still have it be cheaper than paying someone else. With that being said I don't know why they call it painting a car as I spent 99.99% of my time sanding, lol. If you have a garage you can mask off and use I would highly suggest it, the best moment of a build is when when you finally lay some paint down, it's quite fun and there is nothing else like seeing a "project" become a "truck". Just takes a little know how on a few things.
I've been quoted $4000 to have it painted AFTER all the body work was done and it was in primer. Don't be afraid to consider doing it yourself, it's a lot of fun.
Old 05-31-2012, 05:09 PM
KGP50's Avatar
KGP50 KGP50 is offline
KGP50 is starting off with a positive reputation.
I absolutely "second" everything that Sephen67 said! Doing your own body and paint work is a great way develop a satisfying skill that you'll use on other projects and to build your shop & tool inventory (investing your $$ instead of paying it away ). Even if you just get the project through to primer and pass it on to a paint shop for the finish work, you'd be way ahead. I know some shops don't want to paint on others body/primer work but, those that take that approach seem to find a capable and willing shop eventually. When I began my first project, I couldn't begin to understand why a good paint job would cost more than $5,000. When the project was done, I thought $5K would have been a steal!! Anyway ... just a little encouragement here to consider taking it on yourself if you're at all so inclined. -Ken
Old 05-31-2012, 05:41 PM
schoo's Avatar
schoo schoo is online now
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
stephen what is your spray like?
i'v painted some beaters and a little body work but a lead on what tools would help!
roy
Old 06-01-2012, 02:34 AM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Quote:
I strip my cars with a razor blade to this day. Talk about saving a ton of time and sand paper! And actually a lot less of a mess too. Was showed this trick many years back by a veteran backyard painter.
Old 06-01-2012, 07:14 AM
bryanknie's Avatar
Quote:
Yes your 10K number is about where I am at, doing new rubber hardware etc. It may go higher as I seem to be adding on more and more work as this shop does mechanical work too....LOL. Painter stated all parts will be at retail cost or less, so I am OK with that. I have had a few estimates and the shop i am picking has great references seems to have all kinds of classics move through there there every week. This shop does not advertise, but all the guys at the local car shows all use him, he is well respected.
Thanks for the opinion guys I felt like I might be overpaying, but I want a nice job.
I have painted a few things myself, my Model A's etc, I have never paid for much work if any on my toys, I guess I have had sticker shock. However I travel extensively for my job and just dont have the time. I turn 50 this year so this is my Birthday present to my self!
Old 06-01-2012, 10:14 PM
HEAVY100's Avatar
HEAVY100 HEAVY100 is offline
HEAVY100 is gaining momentum as a positive member of FTE.
mine is already primered and waiting for me to choose the color , which I still have no clue what color to paint it .
what would you expect to pay for a quality 2 or 3stage paint job? MARC 1957 - 1960 F100 & Larger F-Series Trucks 6 04-08-2015 11:20 PM
Rustoleum Roll-On Paint Job Jayman1976 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-12-2014 02:17 PM
9K to paint my bare metal truck? Really! Jim-A 1948 - 1956 F1, F100 & Larger F-Series Trucks 97 08-30-2013 05:10 PM
$12,500 cost summary for 1962 restoration to daily driver. old broke prospector 1961 - 1966 F-100 & Larger F-Series Trucks 34 07-10-2013 12:30 AM
Cutting (Sanding) and Buffing COMPLIT1107 Paint & Bodywork 2 05-02-2010 09:16 AM
Tags
2002, average, cost, costs, cover, crossover, ford, full, job, much, paint, price, prices, size, tonneau, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
