M100 replacement clips - Ford Truck Enthusiasts Forums
Old 05-31-2012, 06:39 AM
2quickM100 2quickM100 is offline
2quickM100 is starting off with a positive reputation.
Has anyone found any factory replacement spring clips that hold the chrome trim strip to the bottom fronted grill valance? I could probably just find something that would work....but I wanted this build especially front end be original as possible. The reason the strip needs to be used is that the grill I'm using is the mercury grill and the bottom bolts holes used to attach the lower ford grill are replaced with a spring wire clips that holds the chrome trim down on the mercury one.
Thank you for your reply.
Old 05-31-2012, 06:42 AM
I quess it would have helped putting the year of the truck in...1960 M100
Old 05-31-2012, 06:35 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Minor technicality! Welcome to FTE!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
