Victor-Reinz/Black-Onyx Headgaskets, possible reasons why they fail
Can anybody come up with facts that actually show a thicker gasket has more clamping force? The torque applied to the fasteners (bolts, studs, screws) is what creates clamping force and everyone of those 14mm bolts is putting approx. 16,000 lbs. of force on the gasket.
layer, so that this band squishes more, and has a higher pressure than
the rest of the gasket. this is the primary sealing ridge.
if the gasket were uniform all the way across, then the clamping,
theoretically, would be the same all the way across. that isn't a good
situation here.
the sealant applied to the gaskets, the "secret sauce", is crucial
to the gasket mating with the deck and head surfaces.
i've not bothered to look and see what the specification for surface
finish is for this engine, in microinches, but glass smooth isn't where
it's at usually. you need a very fine amount of tooth on the surface.
what is critical is the consistency of the scratch pattern. i'm guessing
something in the area of 8 microinches would be ideal.
personally, my favorite surface, both in terms of flatness, and
scratch pattern, is blanchard grinding. for cylindrical finishing,
the standard for decades has been a sunnen hone.
a rough guide... (pun intended) can be found here:
Surface Roughness (Texture) Review - Engineers Edge
i am surprised that none of the specialty gasket makers have introduced a product line
to address this problem, other than BO. seems that and OEM are the only choices available.
these folks make annealed copper gaskets for top fuel and whatnot, and i'd bet they could
come up with an interesting product.....
https://www.flatoutgroup.com/Default.aspx
Get your micrometers or borrow one from someone who has and check the diameter of a 6.0 head bolt you will find it's not 12mm like you claim. 12mm equals .472 14mm= .551 and the 6.4 bolts are 16mm which is .630 dia. Anybody have a used 6.0 bolt laying around that you can measure?
LOL - why would you even install a fire ring if it wasn't going to have more force exerted on it than the bulk of the gasket material ............. doesn't make sense.
You might as well also be asking for proof of the materials of construction used by each manufacturer to verify the physical properties of the metals and the soft goods?? They play just as important of a role ..................
Anyway - fact is that there are "structural differences" in the two gaskets and the BO/VR have a higher failure rate. Nuff said IMO.
LOL the fire ring is to prevent burnout.
......... and it does it with compressive force (sealing) and proper materials of construction (as stated)
I would like for you to prove your point .... lets try that approach.
Better yet, call BPD and discuss it with him. IMO the evidence of a weaker design in the BO gaskets is quite conclusive (in the fire ring dimension AND the metal layers) - which was the intent of the post.
I am glad the bolt size is cleared up, maybe some posters will remember what size Navistar 6.0 and 6.4 head bolts are used. As for BPD, they can't even determine what material the head gaskets are made of (stainless?) just a bunch of thickness layer dimensions. Very informitive.
and related areas. i'm sure that with all the people on here, we could
get a dead headgasket for you to dissect, and then you'd be able to clarify
this for us.
i don't have the skills to disassemble a 5 layer cladded metal, and accurately
analyze the composition, but i do have the skills necessary to get a specimen
in the mail to you tomorrow. send my your contact information in a private
message, and i'll have one in the mail to you tomorrow afternoon.
Better yet, call BPD and discuss it with him. IMO the evidence is quite conclusive - which was the intent of the post.
somebody didn't take out the garbage......
you seem to be informed about metallurgy, mechanical engineering,
this for us.
this for us.
That is the way to add value, rather than detract. I am glad to have the thickness information. Makes sense to me. I would love to have the PMI info also. If someone wants to send me the samples of each, I should be able to have the material identified. PM me if you have samples (hopefully my inbox will be clear - at least I am clear for the moment!).
For me, it seems very easy to accept that if a fire ring dimension is greater on the OEM gasket, that the contact the head makes on it as it is tightened down will occur sooner than it would on the BO gasket. Initially, all the force applied to the heads will be exerted on the surface area it first contacts and the force on that area will remain higher throughout the tightening process (the amount depends on the deformation properties of the material), even though the force will distribute itself as contact is made in other areas. Again - I like having information and will not complain about it just because I would like to have more .........
creator
10-24-2012 12:23 PM
csramsey640
11-12-2006 01:27 PM
