Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-30-2012, 04:50 PM
56 ford custom's Avatar
56 ford custom 56 ford custom is offline
Garage is empty, add now
56 ford custom is starting off with a positive reputation.
1960 f100 master cylinder swap?
I have a 1960 f100 short bed with the 292/fordo and all stock brakes. Well im told that I need to ditch the original single master and upgrade to dual master and booster? Even though its drum all around? So my question is do I really need the swap? Also do I need a booster? Who makes a complete kit to directly bolt on with no modifications?
  #2 (permalink)
Old 05-30-2012, 09:58 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
56fc You don't have to change, it is just a safer system. Right now with your original system if you lost pressure for what ever reason, all four brakes are dead. With the newer system the front and rear are separated in the master cylinder so you still have one pair or the other.
There are many kits on the market or you can hit the pick-a-parts. All will require some modification to your plumbing, and at least some adjusting of linkage but you can maintain your pedal assembly.
Good luck in your quest.
PS; the booster just makes it easier on your leg.
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #3 (permalink)
Old 05-30-2012, 10:14 PM
Thanks theodore. I was told there was a direct bolt on kit. Thats why I was just going to pick one up.
  #4 (permalink)
Old 05-31-2012, 04:34 AM
THartman THartman is offline
THartman is starting off with a positive reputation.
On my 1960 the PO ended up parking it after the last time the stock master cylinder failed (again). Putting in a dual is definitely on the list of any changes.
  #5 (permalink)
Old 05-31-2012, 06:50 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
ECI sells an adapter from the original 4 bolt to a 2 bolt mustang dual master cylinder. It is at the bottom of the page.
Power is a choice, how hard do you want to push the pedal. I installed power, but you have to build a bracket that provides clearance if you have a hydraulic clutch. I used the power assembly and bracket (after mods) from a 1973 F-100.
Ford Master Cylinder/Power Brake Booster Mounting Systems
__________________
Walston
http://bigjohnstractor.com/
  #6 (permalink)
Old 05-31-2012, 09:34 AM
truck
Well I dont have to worry about the clutch since my truck is automatic
  #7 (permalink)
Old 05-31-2012, 10:24 AM
Walston's Avatar
1960 Ford F-100
Then a power booster will mount right on the adapter I mentioned above and then the master cylinder. All you need is a vacuum source. Power drum brakes work pretty darn good. Talk to ECI and I think they can fix you up
__________________
Walston
  #8 (permalink)
Old 05-31-2012, 10:42 AM
truck
Quote:
I will have to do that.
  #9 (permalink)
Old 05-31-2012, 03:42 PM
Juette's Avatar
Juette Juette is offline
1959 Ford F-100
Juette is starting off with a positive reputation.
I'm planning on using this setup on my truck. I have heard good things about it from other 57-60 owners.
Power brakes FORD TRUCK , CHROME,1957-1972, F-100, F-250 CHROME | eBay
  #10 (permalink)
Old 05-31-2012, 04:14 PM
truck
Wow $180 buy it now. Not bad. Im just not sure about chrome. My truck isnt very "flashy"
  #11 (permalink)
Old 05-31-2012, 04:29 PM
Juette's Avatar
1959 Ford F-100
Quote:
I understand. I had the same thoughts about the chrome, but I figured I could dress my engine compartment up one part at a time. Here's the less flashy version:
Power brakes FORD TRUCK 57,58,59,60,61,62,63,64,65,-72 | eBay
  #12 (permalink)
Old 05-31-2012, 04:49 PM
truck
Those are very nice but personally I hate boosters they are ugly. Anyone make a direct bolt on dual master kit?
  #13 (permalink)
Old 05-31-2012, 06:56 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
The PO of my 54 gmc used a bendix remote booster. He has the same unit on the two old 3 yard dump trucks he uses in his business. It is mounted on the frame and he used the original single master still in place. This thing flat out STOPS when you hit the brakes. I don't drive it a lot so I always forget and step too hard. I would have gone to a dual cyl, but that's on my list (if I keep it). Soooo, when you pop the hood it looks like 1954 under there, except for the cummins(which he painted gmc colors and mounted a oliver tractor air cleaner with a gmc heater emblem on). The vacuum for the booster (diesels don't produce vacuum)is provided by a ford 7.3 vacuum pump. My point is it has all the stop you'd ever want and no ugly booster. I'm gonna see him on Saturday and I'll ask him where he gets these things.....
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #14 (permalink)
Old 05-31-2012, 07:09 PM
truck
Thanks GB I will be looking forward to that
  #15 (permalink)
Old 05-31-2012, 10:57 PM
H K H K is offline
H K is starting off with a positive reputation.
Click the image to open in full size.
This is my 62 with a bracket and booster from a 65 bolted on to the 62 adapter plate. I also took the pedal from the 65 and put it on my 62 dash bracket. The master is from a '79 F150 and I got the combo valve for it too tucked in the frame behind the steering box. I had to turn the intermediate pushrod in a lathe to fit in the booster diaphragm recess. I modded the brackets some by cutting off the excess below the adapter plate. I have a nice hard pedal with dual circuits and a switching valve in case of rupture now, it makes me feel a little better.
If I hadda known I could have gotten all that for $160 I would have been all over that.
Tags
1959, 1960, 250, 53, 60, clutch, connections, cylinder, f100, ford, master, mustang, power, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
