Oil Leak from HPOP fitting - Ford Truck Enthusiasts Forums
Old 05-30-2012, 04:48 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Here's my problem... found the leak in the valley of death, it's coming from one of the fitting on the HPOP where the line attaches, but it doesn't look like it's coming from the hose, looks like it's coming out of the fitting itself.
Here's a pic:
Any thoughts or suggestions?
I'm trying to sell my 2wd trans so that I can upgrade to a T500 and put new lines on all at once...
Old 05-30-2012, 04:52 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Are you sure its just not the oring on the fitting on the pump?
Old 05-30-2012, 05:04 PM
I'm not sure, I don't know enough about how it all goes together to know for sure.
Right where the arrow is pointing is where it is leaking...
That line attaches to a fitting in the pump. That fitting has an oring on it an is more than likely your leak.
Old 05-30-2012, 05:20 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Darin is right. If it's leaking from there, it's the o-ring on the pump fitting or the line is not tight... Most likely the o-ring. It's an easy fix. Simply take the line off, pull the fitting out of the pump, replace the o-ring, and put the fitting and line back.
Old 05-30-2012, 05:33 PM
Cool deal. Do I need to get that HPOP line tool that Riffraff sells?
Old 05-30-2012, 05:38 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
no it id for the sd pumps not ours
Old 05-30-2012, 05:45 PM
Yep, just standard wrenches.
Old 05-30-2012, 06:21 PM
Sweet! Anyone have a part number for that o-ring? THink the stealership would have one?
Old 05-30-2012, 06:34 PM
Dug this out of the part numbers thread.
High Pressure Oil Pump Fitting O-Rings
(International) 1823790C1?
High Pressure Oil Supply Fittings
(Ford) F4TZ-9C402-A (HP oil pump fitting and o-ring)
Old 05-30-2012, 07:42 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
HPOP o-rings Viton90 .078" .468" .624" Grainger 1WHN4 25/$2.77 -906 *
Old 05-31-2012, 12:34 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Don't mean to throw a monkey wrench (not a pipe wrench Mike) into the works here but the flange on my HP hose had a small crack in it and caused a leak. Small at first until I tighten it down then a very big leak. Its hard to see, very hard, but that might be your problem.
Old 05-31-2012, 12:59 AM
It's not the hose that's leaking, it's definately at the fitting directly off the HPOP. I'd like to get new hoses though, I'm sure they're not in the best of shape after 190k miles.
Old 05-31-2012, 10:21 AM
Quote:
I meant to say the 'flare' was cracked. The local machine shop fixed me up with a new one, I should have gotten two new ones .
Old 05-31-2012, 10:30 AM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Get the Ford or International o-rings! I have tried to fix leaks on the HPOP before with just some plain o-rings and they never last. Sometimes a day, sometimes a week. But they never last. Use the ford o-rings, and follow the directions for the repair. They have an o-ring kit that covers the HPOP fittings, and the serviceable plug on the back. Using the tool from Riffraff would help, but not necessary. You have to push down on the fitting, then pull the hose out. Be sure to push down on the fitting first! What I find amazing, is how loose that fitting is when the engine is shut off, and it doesn't leak! When you grab that line when it's running, it tightens up really tight.
HPOP/Fuel Bowl R&R schlepprock250 1999 - 2003 7.3L Power Stroke Diesel 11 12-21-2014 02:56 PM
1995 PSD - new HPOP O-rings drewthestu 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-10-2014 02:05 PM
Question - looking for suggestions - 97 7.3 no start possible HPOP? Rob Carpent 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-28-2014 12:11 AM
HPOP, Radiator Leaks, and Stop Leak? paddler 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-11-2013 09:27 PM
HPOP removal help flcracker9 1999 - 2003 7.3L Power Stroke Diesel 12 12-07-2007 02:12 PM
Tags
1995, 64, 73, f250, ford, hard, high, hpop, leak, leaking, oil, oring, pressure, pull, pump, removal, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
