Oil Leak from HPOP fitting
Old 06-01-2012, 08:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Talking
Originally Posted by Brown Falcon
Haha, nice Jose!
Originally Posted by strokin'_tatsch
Dang. That o-ring was in bad shape!!! lol
Originally Posted by Talyn
I think Jose showed us his O-face....
All of you are right
  #32
Old 06-01-2012, 11:00 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Except for one thing Jose, you have not participated in the 'add a face to user name' thread, LOL. Ok, I missed it
  #33
Old 06-20-2014, 12:30 PM
Robbieo11's Avatar
Robbieo11
Robbieo11 is offline
Just had this happen went to international. It was closer that the nearest ford joint. Anyway o ring is 1.01 each i got 5 2 for now in winter i will pull the pump and do all 3. I lost a 1/4 of a tank in 8 miles
  #34
Old 06-20-2014, 06:07 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Maybe you meant of the pan, not the tank, right?. . Yes this problem cause a lot of oil leak, because the high pressure oil.
  #35
Old 06-20-2014, 06:24 PM
Robbieo11's Avatar
Robbieo11
Well yes and no had 2 leaks i see hpop was pushing oil at the o rings and fuel line blew it was pointed down and bouncing off the hpop fitting i posted asking what was hpop pumping in a new thread
So look at the fuel hoses they might be rubbing on hpop hose fitting
  #36
Old 06-20-2014, 07:02 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Oh, OK gotcha.
  #37
Old 06-20-2014, 07:14 PM
fordman67's Avatar
fordman67
fordman67 is offline
Wow...relic thread back from the nether world....brown falcon sold his truck didn't he? Sad...sad...sad....
  #38
Old 06-20-2014, 07:52 PM
Robbieo11's Avatar
Robbieo11
Sorry i searched found what i needed
  #39
Old 06-20-2014, 07:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
No sorries here, the search tool is for that and, also this wonderful forum FTE
  #40
Old 06-20-2014, 08:31 PM
fordman67's Avatar
fordman67
Its all good.its nice to see the search feature used actually.sometimes I wonder if some have heard of it lol
  #41
Old 06-21-2014, 05:25 AM
greatestNothing's Avatar
greatestNothing
greatestNothing is offline
Would a leak in this area follow down along the back of the engine? Coat the passenger side axle pivot area? Might have to check this out if so.
  #42
Old 06-21-2014, 06:12 AM
Robbieo11's Avatar
Robbieo11
Yes plus look at the drain valve for fuel bowl might do this also
  #43
Old 06-22-2014, 10:17 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
Yes. The old girl went to a good home with a friend of mine who has big plans for her.
For now, the F150 is working out well for my present needs. I'll get another diesel sometime down the road.
tunastick
10-30-2018 03:46 PM
RedDevil460
06-07-2014 11:42 AM
firewalker250SD
07-26-2013 06:37 PM
jackdanyel
1983 - 2012 Ranger & B-Series
03-03-2013 02:52 PM
PwerStroke99
11-19-2010 02:57 PM
Quick Reply: Oil Leak from HPOP fitting
