Oil Leak from HPOP fitting - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-31-2012, 10:31 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Yeah, dont use crappy o-rings.
This is the same leak I had for 2 years and Never knew where it was coming from till I pulled my pump and found one of the fittings loose.
Old 05-31-2012, 10:35 AM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Old 05-31-2012, 12:17 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
The OBS doesn't have the quick connect line like the SD so you don't need the tool
Old 05-31-2012, 12:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Smile
I also had a oil leak some time ago from the o-ring in one of the HPOP fittings http://www.ford-trucks.com/forums/10...vice-asap.html
Old 05-31-2012, 01:59 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is online now
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Thanks for all the info guys. I got in touch with Joey at Terminator as well and got the same answers. New -6 o-ring should fix it.
Old 05-31-2012, 02:41 PM
Talyn's Avatar
Having the right o-ring for the index and crush is important.
Mine was just loose in general, but had the wrong o-ring from the P/O.
No leaks now. =)
Old 05-31-2012, 03:28 PM
Make sure the fitting is clean and dry, and a dab of loctite on the threads. Ford sends 680 with their kit, as does Guzzle.
Old 05-31-2012, 03:45 PM
Ordered the kit from Riffraff, comes with all 7 o-rings for the HPOP and the loctite for it, all for under $13
Old 05-31-2012, 08:53 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I got a kit from Bob when I ordered a dipstick repair kit. Its in my tool box for 'just in case'.
IIRC Jose, you were on a trip when it happened to you.
Old 05-31-2012, 09:08 PM
I still plan to get a T500 and new lines as soon as I can sell my 2wd trans...
No interest on craigslist yet...
Old 06-01-2012, 10:40 AM
RÖENTGEEP's Avatar
FOREIGN GURU
Thumbs up
Yes sir, was almost a nightmare, but with the help of the people in this forum I figured out with happy end.
Old 06-01-2012, 03:51 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Smile
Here is the culprit and the new one. and when I changed, in the second pic is as my face looked ( ) LOL.
  #28
Old 06-01-2012, 04:55 PM
Haha, nice Jose!
  #29
Old 06-01-2012, 09:05 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Dang. That o-ring was in bad shape!!! lol
  #30
Old 06-01-2012, 09:46 PM
Talyn's Avatar
I think Jose showed us his O-face....
HPOP/Fuel Bowl R&R schlepprock250 1999 - 2003 7.3L Power Stroke Diesel 11 12-21-2014 02:56 PM
1995 PSD - new HPOP O-rings drewthestu 1994.5 - 1997 7.3L Power Stroke Diesel 3 07-10-2014 02:05 PM
HPOP, Radiator Leaks, and Stop Leak? paddler 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-11-2013 09:27 PM
HPOP diagram of drawing? Texas Outlaw 1999 - 2003 7.3L Power Stroke Diesel 58 08-15-2010 05:02 PM
Is there a trick to seating HPOP lines?? mongo75 1999 - 2003 7.3L Power Stroke Diesel 13 09-18-2009 05:44 PM
Tags
1995, 64, 73, f250, ford, hard, high, hpop, leak, leaking, oil, oring, pressure, pull, pump, removal, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
