You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
This is 3rd party information...BUT. A freind of mine has a friend with a 2011 Crew Cab with the 6.2 in it. He tows a 7000k travel trailer with it, and keeps having overheating issues. It keeps smoking the trans. Ford rebuilt it once, then replaced it the second time. Then they added a massivve oil cooler for the transmission, but the engine temp is still at 250*F and the Trans Temp is at 280*F, just from towing this 7k travel trailer. Has anyone else had issues like this? This is the first I have heard of this with these trucks?? What can he look for?
Thanks guys
__________________
2011 F250 R/C Long Bed 4x4 6.2L Tuxedo-Black, Husky Mud Flaps, Dual Mode Reverse/Auxiliary Flood Lights, Air Horn
Custom Side Exit True Dual Exhaust(Think Lightning)
Tuned by *****5 Star Tuning***** Coil On Plug Info Re: Modular Ford Engines
Pulled our 8,400 pound camper from mid Michigan all the way up through the UP of Michigan then down through Wisconsin, Illinois and Indiana on the way home last summer. Never ran hot, pulled the camper like it was not even behind us.
First, what is the frontal area of the travel trailer?
Ford says not to tow a trailer with a greater than 60 sq. ft. frontal area, regardless of trailer weight. (Also worth noting, for a trailer of that weight he needs to be pulling it with either a weight distributing hitch or fifth wheel.)
After that, I would be looking at the trailer's axles and brakes. Make sure the axles are straight and properly aligned, make sure the wheel bearings are good, make sure the brakes are good and properly adjusted. Anything binding or out of alignment could drive temperatures way up, even if it's not binding enough to make it noticeable to the driver.
This is the text message my friend sent me today...
"He hauls a travel trailer, a 7k Utility trailer, and a 15k Dump trailer. The odd thing is it's not consistent. It may go weeks with a combination of trailers with no issues, then all of a sudden it starts slipping like a ****. The trans has been rebuilt or replaced 5 times, new cooler lines, rad and aux trans cooler, PCM has been replaced, trans wiring harness, and transfer case."
So.....this isn't likely to be any of the above mentioned ideas...
__________________
This is difficult to diagnose without having the truck/trailers in front of me. I would be looking for some sort of pattern in the vehicle's behavior and operating temperatures.
Having had basically every mechanical item replaced, it sounds like the issue is either caused by something he is doing wrong or is caused by something software related.
On a side note, he is making sure to use tow/haul mode while towing, right? Towing a heavy trailer in the normal fuel economy mode is a great way to roast a trans. Also, he shouldn't be towing with a new/rebuilt trans until he puts 500 miles of mixed driving on it (break-in period).
This is not a solution posting, just another affirmation that your friends truck is fubar. I tow a 36 foot travel trailer at 10,000+ pounds, and in the heart of summer in high altitudes at times, and the transmission never exceeded 210°
I think you are correct. Mine never gets over 198 while towing with a golf cart in the bed too.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
WOW...I would find another dealer that new what they were doing. Sounds like they are guessing...and then not putting parts back correctly.
Anytime a auto tranny is rebuilt or replaced...the tranny cooling system must be replaced.
I think it might be time for a FORD buy back...that truck is toast!
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
Is that 60 exposed square feet? Or does this take into account how much air the truck is pushing?
I feel for your buddy. I bought '97 350 CC 7.3 and smoked a tranny in 2 days. They replaced it. I drove it home 10 miles and that one was junk too. Luckily, 2 of them in 3 days made it very easy to convince the dealer I didn't want it any more. Turns out a cooler line was pinched flat. I know you said everything's been replaced, so I can't offer anything worthwhile.
