7.3 shuts off while driving tested cps already - Ford Truck Enthusiasts Forums
Old 05-30-2012, 01:27 PM
johnymcfudge johnymcfudge is offline
johnymcfudge is starting off with a positive reputation.
Hello all I am new to the forums and a new owner of a ford truck.
The truck is a 2002 F450 7.3 diesel with about 120k Miles.
While driving from 45-70Mph the truck engine stops for about 1 second and starts back up by itself. I thought the problem was the cps so I replaced it with a ford CPS. Today the problem still persists. The truck engine turns off and comes back on, the tach drops to 0 rpm and so does the speed.
The Check Engine Light comes on and so does the water in fuel light and so does the Check Gage light. After I turn off the truck and start it back up the truck does not show the lights. I am new to fords and would appreciate your help.
EDIT: I believe I found the issue, but can't look into it today. While i was moving some of the wires on the truck I found out that if I move the red/black bunch just a little bit the truck shuts off and comes back on when i let it go. If anyone knows exactly what to look for then I will appreciate it Thank you.
Thank you.
Old 05-30-2012, 01:32 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
I'd check all electrical wiring on top of the engine first. Even the wiring that goes to the big plug on the drivers side. They ware thur and short out sometimes. Also a sticking IPR sometimes do that on the HPOP. Do you have a scaner to check for codes. If so that would be a good step to let the guys on here help you better.
Chet
Old 05-30-2012, 01:35 PM
Unfortunately I do not have a scanner. I heard ford trucks need special scanners to get all the codes. What would be a good scanner to buy?
And I'm sorry but what is the IPR and HPOP.
EDIT: I found the acronyms so I will check those and report back
Also is oil on the cps normal?
Thanks
Old 05-30-2012, 02:31 PM
No, if you have oil on the plug it is probably bad. Thats when you unplug it. I will run unplugged. Contact Clay at Riffraff diesel. He has the best scan package. These motor are electric per say. Theres a lot of it. If its not missing then die, its electric or IPR usually. If your below 1/4 tank of diesel, it could be fuel related to. The foot on the intake tube falls off or breaks.
Chet
Old 05-30-2012, 02:38 PM
How can it run unplugged the Cam shaft position sensor is needed isn't it? It won't start without it. So oil on the Cam shaft position sensor is not good. Ok then I will check on what can be leaking.
Old 05-30-2012, 02:47 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Quote:
Depends on where the oil is at. If it's the part that goes into the engine...oil is normal.
Old 05-30-2012, 02:59 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Yes, Oil will be on the sensor pick-up. The front cover gets oil to provide lubrication to the cam/crank gear.
Old 05-30-2012, 03:39 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
... the tach drops to 0 rpm and so does the speed.
The Check Engine Light comes on and so does the water in fuel light. .....
With those symptoms, I would check the terminals on the PCM and IDM relays. Sometimes they can get a bit corroded and cause intermittent faults.
Old 05-30-2012, 04:05 PM
Quote:
should i replace the relays to be sure? or would the truck not run if they were bad? Thnx.
Old 05-30-2012, 04:09 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Could be a loose fuse, try to wiggle them one at a time while running and see if you can get the truck to die out. If you have any kind of chip I would remove that.
Old 05-30-2012, 04:19 PM
No reason to replace them just yet.
I would start the truck and give the relays a wiggle to see if the engine hiccups. If so, then you found your problem. If not, then you'll have to keep trouble shooting. You can pull the relays and inspect the terminals and see if they look normal. If in doubt, clean the blades with a bit of emery cloth and spray some electrical parts cleaner in the sockets.
You can also swap the blower and PCM relays since they are the same part number. If your blower motor begins to have problems, then a new relay is in order.
Quote:
Since I just got the truck I don't really know where to look to see if I have a chip. Sorry about being so new to these.
Old 05-30-2012, 04:41 PM
PowerstrokeIt PowerstrokeIt is offline
PowerstrokeIt is starting off with a positive reputation.
I am having the same issue!
I replaces the CPS and it didnt change a thing. I bought the one from ford. and when I removed the old one it seemed to be the original one.
My truck only dies going over bumps while holding the break usually. or if i turn the wheel hard to the left and slam the breaks on. I need help too!
Old 05-30-2012, 05:11 PM
tdpower's Avatar
Here is a video of a chip install. Should help to see if you have one.
Diesel Movies - I install a DPTuner F5 chip in my buddies truck. Positions were Stock hi idle 60tow 80econo 120 race 140smoke.
Old 05-30-2012, 08:35 PM
if its from bumps it may be the injector harness. I had that replaced recently on my truck since I was loosing a lot of power.
Replacing the Rear Bearings in your 8.8 equipped E150 - A guide to learning new bad words. 95e150CW 1968-2013 Full Size Vans 20 09-26-2016 10:27 AM
Exploring the Alabama Hills, Lone Pine CA bpounds S. California Chapter 20 11-23-2014 08:11 PM
Adding Cruise Control Update: Home-made cruise installed! dizzyfingers03 1994.5 - 1997 7.3L Power Stroke Diesel 29 04-24-2012 08:23 AM
1951 Ford F4 - Picking it up today. speedyweasel 1948 - 1956 F1, F100 & Larger F-Series Trucks 52 08-13-2011 06:20 PM
Roof Light Cage & Custom Installation On Roof Rack. OGTerror Appearance & Dress-Up 0 04-28-2011 03:06 PM
Tags
1999, 2002, 73, aftermarket, cps, diesel, driving, f250, ford, ranger, reason, shut, shuts, stop, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
