7.3 shuts off while driving tested cps already - Page 2 - Ford Truck Enthusiasts Forums
Old 05-30-2012, 09:36 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
JohnyMcFudge, I'm sorry I miss lead you. I meant, and thought you said ICP not CPS. Thats what I meant about unplugging and thought you had oil inside that plug. If it is
chip'd I had mine shut down once for the same reason. It was loose.
Chet
Old 05-31-2012, 07:11 PM
johnymcfudge johnymcfudge is offline
johnymcfudge is starting off with a positive reputation.
Chet
Its ok, but I noticed a new light come up. The Water in fuel, Check Engine, and the Check Gage light come up after it stalls. I appreciate all of your help guys.
Old 06-01-2012, 06:09 PM
Ok I got the check gage light to turn off. I checked the oil level and it was low. Now I only have the water in fuel and check engine light. I also drained the diesel in the filter and put in another filter. Now the problem is only occurring during when I hit a pothole or a bump. Any ideas?
Old 06-01-2012, 09:26 PM
Unplug the sensor on the back of the fuel bowl. If its bad it usually blows fuse. Maybe it will help and maybe it won't. Are sure you don't have water in your fuel?
Chet
Old 06-01-2012, 09:50 PM
Chet
Yeah i'm sure i don't i just drained everything last night. I found the issue if you check my original post again you'll find what I found was causing a short. I don't know exactly here it is, but i will check it out tomorrow. The fuel bowl is fine all the fuses are good and it seems that when i wiggle the wires in the images I attached the truck turns off and comes back on. When I hit a pothole or a speedbump i'm guessing they move and that's what is causing the issue. I will investigate further tomorrow. If you have any idea of what these wires go to and what may be causing it please reply back.
Old 08-25-2014, 12:32 PM
94PSDF250 94PSDF250 is offline
94PSDF250 is starting off with a positive reputation.
This could be a bit late to get but I can not get the 2 pics of the Red and Black wire mentioned at the end of the first post. If anybody can see them can you tell me where they are in the truck. I am having this same issue and those 2 wires might be my problem.
Thanks
Old 08-25-2014, 12:59 PM
Quote:
Thanks
Sorry I can't find the original images... but i have some images that are a bit blurry but should help. I added some more text to help.
Old 01-25-2015, 07:18 PM
ssolid ssolid is offline
ssolid is starting off with a positive reputation.
Dangerous situation
Tonight I had this happen with driving rain on the interstate.
Wipers went slow, back wiper went on its own, water in fuel and wait to start lights came on and headlights dimmed and/or turned off.
Came back on its own but did it several times on the way home.
When I got home, i flashed the brights and that stalled the engine.
On and off about 20 times, the rear wiper would go on its own and the left blinker light on the dash would stay on...The headlights would dim when this happens.
Also, none of the buttons on the doors are lit. They used to flicker on and off but now they are off permanently.
Thanks for your help
Ssolid
Old 01-25-2015, 07:31 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Ssolid
For that many things to happen all at once, my first guess is battery connections. Ground wires, all battery posts, connections going to the starter, check them all.
Old 01-25-2015, 09:06 PM
I will look at as many connections as possible. I am definitely going to look at the harness. That has caused me consternation in the past.
Any fuse or relays to look at?
I thought it might be the multifunction switch MFS but not so sure now?
It is my wife's and 4 kids daily driver and I need to solve this problem fast.
If I can't find the fix, what are suggestions as to who to get to look at this crazy type of problem?
Thanks
Steve
Old 04-29-2015, 11:54 AM
99 350 99 350 is offline
99 350 is starting off with a positive reputation.
Not sure if youve fixed this or not yet. I had similar problem with my 02. Theres a big power wire that runs to junction block on drivers side inner fender well. My wires broke over time and werent connecting then they broke off completely. 6hrs beside road for me to find. Hope this helps
Old 04-29-2015, 03:29 PM
Ground.
Quote:
I had a loose ground on the firewall on the driver side. Aftermarket air filter setup was on the same connection and it wiggled it loose.
Thank you to everyone for your help and suggestions that enabled me to diagnose and fix the problem.
Steve
Replacing the Rear Bearings in your 8.8 equipped E150 - A guide to learning new bad words. 95e150CW 1968-2013 Full Size Vans 20 09-26-2016 10:27 AM
Exploring the Alabama Hills, Lone Pine CA bpounds S. California Chapter 20 11-23-2014 08:11 PM
Adding Cruise Control Update: Home-made cruise installed! dizzyfingers03 1994.5 - 1997 7.3L Power Stroke Diesel 29 04-24-2012 08:23 AM
1951 Ford F4 - Picking it up today. speedyweasel 1948 - 1956 F1, F100 & Larger F-Series Trucks 52 08-13-2011 06:20 PM
Roof Light Cage & Custom Installation On Roof Rack. OGTerror Appearance & Dress-Up 0 04-28-2011 03:06 PM
Tags
1999, 2002, 73, aftermarket, cps, diesel, driving, f250, ford, ranger, reason, shut, shuts, stop, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
