1979 rear slip yoke - Ford Truck Enthusiasts Forums
1979 rear slip yoke
Old 05-30-2012, 08:14 AM
marmon77 marmon77 is offline
marmon77 is starting off with a positive reputation.
1979 rear slip yoke
Does the rear slip yoke just slide off or is there some type of retainer ring holding it on? My is really stiff and won't slide at all I have to tap it with a hammer to get it to move. I broke 2 U-joints so far I think it's because it won't slide. Was gonna take the yoke off and clean it then grease it. Thanks
Old 05-30-2012, 08:16 AM
The1nOnlyFordBoy's Avatar
The1nOnlyFordBoy The1nOnlyFordBoy is offline
The1nOnlyFordBoy is gaining momentum as a positive member of FTE.The1nOnlyFordBoy is gaining momentum as a positive member of FTE.
should slide off
Old 05-30-2012, 11:08 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
The retainer is probably pressed on.
75 Highboy driveshaft slip yoke orientation Colorado Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-21-2016 04:13 PM
292/Ford-O-Matic Rusty_S Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 18 11-07-2015 08:09 PM
Drive shaft slip yoke problem sperober1 1997 - 2003 F150 1 07-01-2014 07:47 PM
Slip Yoke Removal Steel Toy 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-16-2011 01:28 PM
swapping rear outputs on a np208 Blue_Betty 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-23-2010 11:06 AM
Tags
1977, company, ford, holding, oklahoma, personal, powered, slip, vbulletin, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
