C6 backup light switch
I cannot get the backup lights to come on when the vehicle is in reverse. The switch is adjusted all the way to the stop but it needs to go a little farther. I have even cut one of the mounting ears off to increase the range but it still is not enough. Is it possible the selector shaft is clocked wrong? I have tried two seperate switches with the same results. The trans was rebuilt just before I bought the truck and the lights have never worked. The wiring & lamps are OK. They light, just not when in reverse. I need to install a backup alarm & it has to be automatic (for loading dock access). Any Suggestions? "82 E350 box 351W & C6
mythbustingpyro
06-19-2013 05:45 PM
pedrorairez
23
01-22-2007 09:21 PM
