2003 f-150 4.6l high idle at startup
Old 05-30-2012, 01:03 AM
herb76's Avatar
herb76
herb76 is offline
i've got a 2003 ford f-150 with a 4.6l 150000 miles. when it is started the rpms are at 2000 for about a min. and a half then it drops to normal when its started cold. when started at opperating temp. the rpms are at 2000 for about 30 to 45 sec then drop to normal. the iac, upper and lower intake gaskets, intake run controler valve, dfbe, low intake and shield, coolant temp. sensor, intake air temp. sensor, egr, egr regulator valve, maf, ecm have all been swaped out no vacuum leaks all line in good condition tps voltage reading of 0.84v l'm at the end of my rope on this and ford has been no help
Old 03-03-2013, 12:31 AM
daboot's Avatar
daboot
daboot is offline
Did u find a solution having the same problem
Old 03-31-2013, 08:52 AM
Rednek Canuc's Avatar
Rednek Canuc
Rednek Canuc is offline
I'm not by any means tech swavy but had this happening to my 01 xlt pulled my air filter put in a k&n reusable air filter noticed some of the hoses attached to the intake were sliding off put them back in place they came loose again so used a couple hose clamps to keep them seated and sealed this rectified that issue hope that helps you out
jbalestri
Modular V8 (4.6L, 5.4L)
02-22-2022 06:49 PM
hgbyrne
1997 - 2003 F150
07-29-2010 08:05 AM
cajun1965
1997 - 2003 F150
03-05-2010 04:23 AM
WV Hound Dog
1997 - 2003 F150
02-16-2008 10:15 PM
leon45
3.8 & 4.2L V6
11-08-2004 10:16 AM
Quick Reply: 2003 f-150 4.6l high idle at startup
