2003 f-150 4.6l high idle at startup - Ford Truck Enthusiasts Forums
Old 05-30-2012, 02:03 AM
herb76 herb76 is offline
herb76 is starting off with a positive reputation.
i've got a 2003 ford f-150 with a 4.6l 150000 miles. when it is started the rpms are at 2000 for about a min. and a half then it drops to normal when its started cold. when started at opperating temp. the rpms are at 2000 for about 30 to 45 sec then drop to normal. the iac, upper and lower intake gaskets, intake run controler valve, dfbe, low intake and shield, coolant temp. sensor, intake air temp. sensor, egr, egr regulator valve, maf, ecm have all been swaped out no vacuum leaks all line in good condition tps voltage reading of 0.84v l'm at the end of my rope on this and ford has been no help
Old 03-03-2013, 01:31 AM
daboot daboot is offline
daboot is starting off with a positive reputation.
Did u find a solution having the same problem
Old 03-31-2013, 09:52 AM
Rednek Canuc Rednek Canuc is offline
Rednek Canuc is starting off with a positive reputation.
I'm not by any means tech swavy but had this happening to my 01 xlt pulled my air filter put in a k&n reusable air filter noticed some of the hoses attached to the intake were sliding off put them back in place they came loose again so used a couple hose clamps to keep them seated and sealed this rectified that issue hope that helps you out
4.6L runs rough between 1000 an 2000 rpms kyle_explorer Modular V8 (4.6L, 5.4L) 6 05-15-2016 11:23 AM
89 5.0 will not come to normal temp totalimpact 1987 - 1996 F150 & Larger F-Series Trucks 15 01-16-2014 12:02 AM
Expedition towing power loss, no codes jhfishdad 2007 - 2014 Expedition & Navigator 6 01-03-2014 10:36 AM
2003 f150 4.6 high idle, ludging and hard shifting manchu76 Modular V8 (4.6L, 5.4L) 2 07-12-2013 03:05 AM
sluggish throttle no turbo fart zss42002 6.0L Power Stroke Diesel 15 02-19-2013 04:00 PM
Tags
03, 2003, 46, 97, brakes, expedition, explorer, f150, fast, ford, high, idle, runs, start, startup, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
