A/Os 1/2 ton axle rebuild and SASsy thread -with a pic or two - Ford Truck Enthusiasts Forums
Old 05-29-2012, 09:10 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Since FTE could use another SAS thread heres what Ive been working on the past couple weeks for a friend.
84 F150
9" rebuild
housing stripped bare and wire wheeled
Had to weld one spring pad back on
Painted gloss black
The 3rd member already had 4.10 gears so we kept that but gutted the open carrier for a mini spool. The rest of the parts in this pic are 44 stuff
everything removed and cleaned up
Open carrier with the ring gear removed. Bust it in half
Knock out the 3 roll pins and remove the cross pin, spiders and side gears
Throw 'em in a box
Its cute
Stick it in the deep half of the carrier along with the shims that were behind the side gears
Stock cross pin on the left chromoly on the right.
Stick it in the hole and drive one of the roll pins back in.
Slap it back together and bolt your ring gear up - torqued to 60ft lbs with red locktight
Old 05-29-2012, 09:24 PM
Set it back in the 3rd member - caps torqued to 60ft lbs with red locktight
use the spanner wrench you made because youre too cheap to buy one
Had to put a new pinion seal in
Cast coat aluminum high heat paint....
Put it in
Press new studs in as necessary
Paint the brake backing plates
Slap 'em in and install new brakes. No parking brake
Bend lines
Slap it in the truck. I reused the factory 2" block but I think he is going to buy a set of 4" springs. The front is a little high and I want to ditch the block.
Hes also bought a new set of shocks but they havent come in yet.
Old 05-29-2012, 09:43 PM
Greasy rusty turd as delivered
Stripped down and wire wheeled
Paint
The axle came with 3.25 gears. Ive never seen one with that high of a gear and I dont think its factory. Not sure why. Oh well, order gears, carrier and install kit.
Remove the side gears and spiders from your 3.91-down carrier and install them into your 3.92-up carrier. Basically the same as the 9" carrier above except dont try to bust this one in half Notice the difference in offset.
Everthing together before the first go'round on the shims. The ring gear bolts were torqued to 55ft lbs with red locktight.
Press the pinion bearing in
Ready to go
Race
Pinion
Zang! Took 4 tries for me to get right.
Old 05-29-2012, 09:53 PM
Hubs and rotors
Press new races in, pack bearings and install the outer wheel seal.
Slap the shafts in
Add finishing touch to **** off owner
Caliper bracket, spindle, wheel hub/rotor and outer wheel bearings on.
Install blingness and repeat.
Wait on parts from the big brown chariot. 4" Deaver Superflex springs and 7* bushing set
Install brake lines, 7" extended brake line for a 79 F150 and radius arms. Basically complete in this pic minus calipers.
Old 05-29-2012, 10:06 PM
Now the fun stuff...
For tie rods, drag link and trac bar we are using 1.5 x .250 DOM with 5 -3/4 thread x 3/4 bore and 1- 3/4 thread x 5/8 bore chromemoly heims with kevlar liners. All hardware is grade 8 and pinned with a cotter key so it cant wiggle loose. We are also using misalignment spacers at the top of the passenger knuckle and at the pitman arm. You will need to drill the taper out of the knuckles and the pitman arm to make this all work.
More on this later.
Get that POS out of there
I salute you! Link'd
http://i253.photobucket.com/albums/h...-59-55_705.jpg
All gone
Roll the new axle under there
Bolt your blingdaddy superflex springs into the stock 84 coil buckets - I did this out of spite to the interwebs since Ive read numerous times it will not work and that 73-79 buckets are required.
bottoms
I used stock 79 F150 radius arm brackets instead of the TTBs. If you notch the brackets to clear the body mount and use the rear ttb bracket hole on the frame in the front hole of the radius arm bracket it works perfectly.
notch them like this...
bolt that shat up!
Old 05-29-2012, 10:16 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Mini spool bad. Better off making one with spiders n two cross pins.
Everything else looks good.
Old 05-29-2012, 10:26 PM
Trac bar bracket cut down from an old set of 4 link brackets
All done
Trac bar and drag link are within 1/2* of being perfect.
yes, thats a chrome diff cover.
On the brakes...
A 84 (not sure what other years for complete certain but Im pretty sure 80-96) the brake lines come off both sides of the frame with a seperate line coming from the proportioning valve. For this truck I used the 79 style lines and routed the line from the pumpkin (where it meets the juction block and is distributed to each caliper) straight up to the proportioning valve in the driver side line hole and capped off the passenger side with a pipe plug.
Next for this project will be a MSD 6al and coil, electric fuel pump and regulator, new valve springs to match the cam, shocks and a few other little things. I may also end up swapping torque converters for something a little higher stall.
Old 05-29-2012, 10:27 PM
Dave, I agree but I guess it will work until it doesnt.
Old 05-30-2012, 04:05 PM
im2tall33's Avatar
im2tall33 im2tall33 is offline
ID CHAPTER LDR
im2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputationim2tall33 has a superb reputation
thats a nice looking 84!!!
Old 05-30-2012, 04:17 PM
77mud's Avatar
77mud 77mud is offline
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
Neg reps for putting on the chrome cover instead of the pink one
Old 05-30-2012, 05:21 PM
Paying customers get whatever color/finish diff cover they want.
Old 05-30-2012, 05:24 PM
77mud's Avatar
lol i hear that... you talked him into a 460 yet?
Old 05-30-2012, 05:44 PM
Naaa...
Im going to tinker on this engine until we pretty much max it out.
Old 05-30-2012, 06:15 PM
77mud's Avatar
you say it was 302 or 351?
Old 05-30-2012, 06:55 PM
ibleedblue1385's Avatar
ibleedblue1385 ibleedblue1385 is offline
ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.ibleedblue1385 has a great reputation on FTE.
Thats a stout looking truck.
Good work!
STGs D60 tech thread Part 2- Crossover steering STGFordCrazy04 Offroad & 4x4 39 04-11-2015 11:06 AM
George v4.0 alpha/omega Offroad & 4x4 365 10-14-2013 03:13 PM
STGs D60 Tech Thread 4 - D44 vs D60 with pics pics STGFordCrazy04 Offroad & 4x4 45 09-16-2008 09:58 PM
Top Fuel Hydro drag boat race in Augusta STGFordCrazy04 South Carolina Chapter 3 07-25-2008 11:57 AM
STGs D60 tech thread Part 3- useful diagrams and a trick STGFordCrazy04 Offroad & 4x4 45 06-14-2008 11:41 PM
Tags
:flip, arm, drunk, econoline, knuckle, pictures, rebuilt, steering, ton, truckscom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
