A/Os 1/2 ton axle rebuild and SASsy thread -with a pic or two
#201
#203
Thanks mang.
I also put a quasi-vinyl/plastic dash pad cover dealio over the cracked factory dash. The interior looks pretty dang good imo
Im waiting on a new distributor gear (loooooong story - not my fault at all) and i need to bolt up the front d-shaft and this bich is done! Its been a helluva 5 months and Im glad to be finished
#207
Never bolted the front drive shaft up after swapping headers so I did after slapping in some new joints and a coat of paint.
The joints are Carquest #1-0134 (axle end) and #2-0631G (t-case end) if anyone needs it. Im sure they cross to a Spicer #.
Made an oil pump primer because the 5/16 socket welded to a long 1/4" extension I always use for 460s wouldnt work. Its just an old distributor cut down and a 5/8" nut welded to the shaft. 18v drill turns it great.
So, got it running today after a few hiccups but all is well. I need to wire the lights for the gauges and take if for a test drive. Owner is taking delivery on Sunday and the shop is getting a new toy on Monday - not sure what, yet.
#210
Received 3,101 Likes
on
