Timing Adjustment
Old 05-29-2012, 08:09 PM
Dylan Davenport's Avatar
Dylan Davenport
Dylan Davenport is offline
Timing Adjustment
I have an 1984 Ford F150, I need to adjust the timing, but i have no idea where the timing marks are.. any help?
Old 05-29-2012, 08:16 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,680 Likes on 1,357 Posts
They are on the harmonic balancer behind the lower pulley if you have a v8. If you have a six, they may be in a different spot.
Old 05-29-2012, 08:47 PM
Dylan Davenport
It's a V8 5.8L
Where is the Harmonic Balancer?
Old 05-29-2012, 09:00 PM
82f100460's Avatar
82f100460
82f100460 is offline
oh boy!!!
Dylan....welcome to the furum.
As Dave stated, it is right behind the lower (crank) pulley. It is actually what that pulley bolts to. The balancer fits right onto the crank shaft itself so is driven by the crank...which then drives the pulley.
The marks are right on the balancer, it's about 1.5" wide...just looks like a big disc.
Do a google on it and you'll see lots of pictures
Old 05-29-2012, 09:02 PM
82f100460's Avatar
82f100460
Be careful while you're doing this....remember there is lots of moving parts up there when you're setting the timing...like the fan and all those belts
Old 05-29-2012, 11:05 PM
Dylan Davenport
Okay, now that I found that, how do I adjust the timing to where it needs to be. (10 Degrees BTDC) How do i get it there?
Old 05-30-2012, 01:59 AM
kedwinh's Avatar
kedwinh
kedwinh is offline
I guess my first question would be, what makes you think you need to adjust the timing?
To answer your question, you have to loosen the hold down bolt on the distributor then move it left or right to align the timing marks where you want them. Make sure you remove the vacuum line and plug it before you adjust the timing.
Old 05-30-2012, 07:29 AM
Anafiel's Avatar
Anafiel
Anafiel is offline
I would also suggest doing a search at youtube and get a general idea on how to adjust timing on an engine.
Seriously, be careful of the fan when you this.
I would also suggest cleaning the harmonic balancer at the timing marks before you do this, and taking a very little paint brush and highlight 0°, 10°, 12°, and 14°
It'll make it easier to see the marks with the timing light, and it'll hold up for the next time you need to set the timing.
Old 05-30-2012, 08:13 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Dylan - These guys are right, on all counts. First, this is a dangerous job as the fan blades BITE. Second, if you didn't know where the timing marks are you can't know if you need to set the timing. So, get yourself a timing light, clean and mark the harmonic balancer as suggested, and check the timing - with the vacuum advance disconnected. And before you ask, the vacuum line is the hose to the distributor - and it is possible you have two of them so pull and plug both.
My bet is that you'll find the timing is where it should be. These ignitions are pretty stable.
Old 05-30-2012, 04:35 PM
whisler's Avatar
whisler
whisler is online now
Unless it is a 5.8 H.O., he has no vacuum advance, it's a computer controlled distributor.
Old 05-30-2012, 08:56 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
There you go, spoiling everything with facts. Yes, you are right - as usual.
Old 05-30-2012, 09:37 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
Does that mean it has a "Spout" connector that need disconnected like the 4.9?
Old 05-30-2012, 09:41 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I believe that is true. Not sure about the 460, but the 302 and 300/4.9 should have had then. The 351 HO didn't, but I was thinking that was 85 & 86, not 84.
Old 05-30-2012, 11:03 PM
Anafiel's Avatar
Anafiel
Anafiel is offline
Now you're really gonna confuse him....
Dylan, get a repair manual for your truck, year specific. Hang out here and ask questions. Post pictures, we'll do the same.
Enjoy the experience!
rickeylipham
11-24-2007 02:07 PM
re54drider
03-19-2006 08:05 AM
bobbarob
06-01-2003 11:24 PM
therigwelder
06-19-2001 02:34 PM
samisage
08-04-2000 06:41 AM
Quick Reply: Timing Adjustment
