Need help! timing issue.
I just rebuilt my 400 in my 77 f250. It has new timing gears and chain. New mild cam. New distributor. New pistons. New fuel pump. New carb. I got it back in the truck and got it to fire up when I timed it at 8* btdc. It lugged so I started advancing the timing. It got to 22* btdc before it smoothly idled. It starts fine and runs fine but it seems very high for the timing. I hooked up the advance vac line revved to 3000 rpms and it goes up past 40* btdc. I already checked the timing marks to see if balancer slipped and timing gears to see if I'm a tooth off. Anyone have any ideas?
Well unless it happens to be a tooth off, my guess would the new parts made that carb to small
Not a problem. It probably would of but changing cam and pistons is probably whats getting u for not having enough cfm now
70T351W
05-04-2006 07:05 PM
hartattack
01-22-2005 08:36 AM
cdd5599
10-22-2002 04:04 PM
