3.0 Taurus Pan Gasket??? - Ford Truck Enthusiasts Forums
Old 05-29-2012, 03:04 PM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
Can the engine oil pan be removed on a 2001 3.0 Taurus without dropping the Y pipe? Pan gasket is blown out under the timing cover, is this a common problem?
Old 05-29-2012, 09:26 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
That's a pretty common issue on those motors. Yes, you have to lower the Y pipe for clearance. There is an updated gasket available to prevent this problem.
I've never done it myself, but I've seen guys loosen the oil pan and clean up the pan, timing cover and seal with solvent then reinstall it. As far as I know it lasted the life of the car. It's a formed silicone seal so it shouldn't shrink with age. Might be worth a shot.
Make sure your PCV system is working correctly. I suspect crankcase pressure is what causes it to work its way out over time.
Ford taurus 3.0 in Escape? wenter Escape & Escape Hybrid 26 12-12-2016 09:50 AM
Taurus to Escape Swap mikewohlwend Escape & Escape Hybrid 3 12-14-2015 12:52 PM
2000 Taurus 3.0/V6 3g alt in an 89 F250???? Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-16-2014 09:52 PM
3.0 Taurus and 3.0 Ranger are they the same engine? lilwrkmstr Ranger & B-Series 3 09-15-2008 06:54 PM
taurus motor in ranger seth1 Ranger & B-Series 10 02-14-2004 05:22 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2001, 30, 96, cover, duratec, engine, ford, gasket, oil, pan, replace, taurus, time, timing, v6, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
